Fog light wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Renegade946, May 3, 2019.
  1. May 3, 2019 at 8:09 AM
    Renegade946
    Renegade946 [OP] New Member
    David
    2018 Toyota Tacoma SR5
    Replaced all factory lights interior and exterior with LED's. Installed bull bar with LED's. Installed a light strip on the rear.
    I have a 2018 Tacoma with factory fog lights that are wired into the turn signal and headlight lever on the steering wheel. I bought a push button fog light switch for the dash and I would appreciate it if someone that knew how to change the wiring from the steering wheel to the push button switch would fill me in because I am not sure how to do it. Thank you in advance for any help.
  2. May 3, 2019 at 9:40 AM
    caribe makaira
    Caribbean, Puerto Rico
    https://www.tacomaworld.com/threads/nitoris-oem-sr-foglight-mod.451495/
    P.S. Buy the wire mentioned in that post, remove the one you have (no cutting), replace the removed one with the one you bought. Connect the other end to switch. When you have wife's permission then buy the proper stalk and install, remove wire from connector and place original back, your set.
    Renegade946[OP] likes this.
  3. May 3, 2019 at 10:05 PM
    caribe makaira
    And then sell the wire and switch to get chocolates.:proposetoast::drunk:
