Fog Light Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tj2431143, Nov 18, 2022.
  1. Nov 18, 2022 at 3:56 PM
    Tj2431143
    Tj2431143 [OP] Member
    Timothy
    2015 Toyota Tacoma Access Cab Base
    Hello!
    Just a quick question.
    Is it possible to wire fog lights in to my truck without wiring to the battery?
  2. Nov 18, 2022 at 4:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The stock fog lights or are you adding aftermarket ones?
    The answer is yes either way, just depends on how you want to do it.
  3. Nov 18, 2022 at 4:01 PM
    Tj2431143
    Timothy
    It would be aftermarket.
  4. Nov 18, 2022 at 4:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is your truck a 5 lug or 6 lug.
    Some trucks are already wired for the fog lights. (Most were 5 lug)
    It’s a little more expensive this way, but it’s plug and play.
  5. Nov 18, 2022 at 4:20 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Without sounding too harsh, it sounds like you have very little automotive wiring experience. If so, I'd get somebody who's done this a few times to help you avoid burning your truck to the ground. It's not difficult, but done incorrectly, things can go very wrong.
  6. Nov 18, 2022 at 4:24 PM
    Tj2431143
    Timothy
    It is a a 5.
    I've looked all over the front end and even behind the blank switches. It's not a prewired unfortunately.
    TnShooter[QUOTED] likes this.
  7. Nov 18, 2022 at 4:26 PM
    TnShooter
    Deogee
    STOCK
    Wiring it to the battery with a fuse, switch, and relay is the easiest solution.
    Other wise, you’ll need to find an existing circuit capable of carrying the extra load from the fog lights.
    I don’t recommend it however.
  8. Nov 18, 2022 at 4:45 PM
    Tj2431143
    Timothy
    Awesome!
    From everything I read that seemed like the best way, but I just wanted to see if there were any other options.
    Thanks for the great info!
