fog lights 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 53wick, Nov 27, 2012.
  1. Nov 27, 2012 at 10:58 AM
    53wick
    53wick [OP] Well-Known Member
    kentucky
    2014 accesscab prerunner
    has anyone installed the fog light kit on there truck. there on ebay for around $150.00. any problems with them? my concern is the the t-tap connecters on the fuse box behind the kick panel. are these t-tap connecters made that there open up, lay the factory wire inside and when closed they cut into the wire, getting a connection? truck is one week old do not want to cut the factory wire harness. thank you dave
  2. Nov 27, 2012 at 11:37 AM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    Buy an add a fuse from ur local auto store and solder it to the power wire. stick it In one of the empty fuse slots that has voltage only when the ignition is on, instead of touching any factory wiring. I've done it this was on my 10 and will do it when I get my 13 and bunch of others have also.
  3. Nov 27, 2012 at 1:11 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    theres no need, if your AC is a v6 your already pre-wired. just buy; the Camry lamps on ebay, relay, and OE switch, you're done for less than $110. there is TONS of recent info on this consolidated into a few popular threads. they contain, how-to, part numbers and sources.
