FOG LIGHTS ANYTIME THE SIMPLEST WAY
Discussion in 'Lighting' started by o0oSHADOWo0o, May 31, 2014.
  1. May 31, 2014 at 11:52 AM
    o0oSHADOWo0o
    o0oSHADOWo0o [OP] Just Lurking in the Darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    BHLM with amber LED "eyebrow" strips and Angry Red Eyes, Black Depo Tail lights, Knight Rider Hood Scoop Mod, Amber Grill Backlighting, Amber Lamin-X Fog light film, Fog Lights Anytime Mod, Black T-Rex Grill Inserts, Red interior LED lighting, Go Rhino 5" Oval Nerf Bars, Modified side mirror turn signals, Drill-less license plate relocation bracket. OEM Bed mat. Weather Tech floor mats.
    Ok, it seems a few people have different ways of doing this. I have a way that uses NO parts, requires NO bending, NO cutting, NO splicing, and a bare minimum of time and tools. Are we ready? :D
    This works on my 2012 4x4 Double Cab TRD Sport. It may not work on older trucks due to changes in the wiring and fuse configuration.
    First, remove the fog light relay
    Next take the relay box off and flip it over. There is a cover on the back side that can be taken off to access the wiring.
    Finally, locate the two wires indicated by the RED ARROWS. This picture shows the wires already switched.
    The connectors can be pushed out from the TOP (relay side of the block) with a jeweler's or precision screwdriver. There are little plastic tabs that hold these in. It takes a little practice and patience to push them out but it isn't that difficult.
    Once you get both wires loose, simply swap them, reinstall the bottom cover, relay and top cover and you're ready to go. Your fog lights with come on with the switch anytime your ignition is on.
    This works because the fog light switch switches the negative side of the circuit to the fog light relay coil. The wire that was swapped has +12v on it anytime the ignition is on. This is used to power the positive side of the relay coil. This is too easy to do! :D
  2. May 31, 2014 at 12:05 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    '12 TRD Sport DCSB 4X4
    Click My Sig Homie
    Good post, I did it this way too, getting those wires out is aggravating though, if I hadn't got the first one, I was off to do it the other way.
  3. May 31, 2014 at 12:24 PM
    pdctaco12
    pdctaco12 Well-Known Member
    Phillip
    Western North Carolina
    2012 TRD Sport DC SB
    Anytime fogs, bkack emblems, horns, and blacked out center caps
    That's the way I did my 2012 and no one will ever know. That's the best part about doing this way.
  4. May 31, 2014 at 12:35 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Yep ! I like to incorporate a bit of stealth into what I do.
    I haven't gotten around to making a clean drawing of it and posting it yet, but I have done a mod that lets the turn signal on the mirrors come on with the parking lights but still function as turn signals. I'll have to finish the details so I can post that too.
  5. May 31, 2014 at 12:37 PM
    Bsheriff11
    Brandon
    Click My Sig Homie
    Now id like to see a write up on the turn signal mod, pretty cool
  6. May 31, 2014 at 12:56 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Here are some pics. I need to clean up the wiring diagram.
  7. May 31, 2014 at 1:01 PM
    Bsheriff11
    Brandon
    Click My Sig Homie
    I can't read too much into those pics, but if you could do a write up detailing how you did it I would be grateful :)
  8. May 31, 2014 at 1:07 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Yeah...I'll get around to it soon. I just wanted to show you that it had been completed. I basically took 3 DPDT relays, one for each signal and one for the parking lights, strung them together and hooked them up. I know....details do help:rolleyes:. I'll write it up soon.
  9. May 31, 2014 at 1:12 PM
    Bsheriff11
    Brandon
    Click My Sig Homie
    Just realized you're from Virginia :cool: .....VA takin ova here recently
    JeffP213 likes this.
  10. May 31, 2014 at 2:40 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Just went to try this on my 2014 TRD OR. I don't seem to have all the wires to swap! Help!
  11. May 31, 2014 at 7:33 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Well damn. :( I guess it sucks to have a 2014 then :rofl:
    Seriously though, you can do this one of the other ways. There are a few threads out there on this. All you really need to do is to bring +12V that comes on with the ignition to the Silver prong on the left side of the fog light relay. Some people remove the relay and install "jumper" wires and some just bend that prong and attach a wire to it.
  12. Jun 1, 2014 at 2:44 PM
    2wdTRD
    2wdTRD Well-Known Member
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    You got my hopes up, I'm sitting in the driveway looking at the box and this picture and its seriously different. Here is what us 13+ owners are looking at, any help will be greatly appreciated. Also I was looking at the picture of the relay box you posted, I'm going to assume that on your 12 the relay for the fogs is the blue on the bottom. On the 13 its the bottom blue relay.
    I'd rather use your solution here than another, with only 11,000 miles I'd like to keep things as OE looking as possible.
  13. Jun 1, 2014 at 5:25 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Ok, no problem. We can work with what you have. My photo shows the +12v wire for the fog light relay coil and the +12v wire for the seat heater relay coil already switched. Below is an edited copy of your photo. Just switch the blue wire with the white stripe, indicated by the red arrow and the red wire with the black stripe, indicated by the other red arrow. This uses the +12v wire for the air pump relay. This also is energized when the ignition is turned on. Let me know if this works for you. :D
  14. Jun 1, 2014 at 6:37 PM
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    I'll attempt this tomorrow after work, only thing I'm thinking is if I pull the 12v from the air pump does it have another source of power at start up? Earlier I pulled the relay for the air pump and turned on the key (had a dumb moment and forgot to just check the lid for relay ID) anyway after I put it all back together and started it I had the CEL on for the air pump. I cleared it after all was back together and it has stayed off, but will it set the CEL if I pull it's 12v?
  15. Jun 1, 2014 at 6:53 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    So you actually have an air pump? Hmmm. I don't have a seat heater or an air pump, just two empty relay sockets. In your case all you really need to do is get +12v power to the fog light relay coil where red/black stripe wire is.
    Here is a solution but requires cutting wires. You could put a quick tap on the Blue/White stripe wire, then cut the Red/Black Stripe wire and connect it to the Blue/White wire with the quick tap. Make sure to cap off the end of the now unused Red/Black wire from the harness.
    This would all be concealed by the bottom cover of the relay box. I would prefer this over any of the other mods that are painfully visible.
  16. Jun 1, 2014 at 7:10 PM
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    Yea sadly I have an air pump in a non smog/non testing state, I would much rather prefer to keep all things hidden but more importantly being able to switch back for warranty reasons if needed. I'll have to take the other option of just making a harness for the relay that does not require any bending or cutting...
    I appreciate your help!
  17. Jun 1, 2014 at 9:05 PM
    WILLIAM ROBERT
    WILLIAM ROBERT Well-Known Member
    Edmonton
    it's blue
    sweet deal Shadow, worked for me, thanks. I have an air pump too, but no heated seats.
    nice truck BTW.
  18. Jun 7, 2014 at 3:06 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Glad to help, and thanks for the vote of approval on the look of my truck. :D
  19. Jun 9, 2014 at 1:15 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Dunlap,TN
    13 MGM Sport 6sp AC
    Sub to try later on my 13
  20. Jun 11, 2014 at 7:56 PM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, DynaPro 265/75/16 ATMs, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    Took me a while to figure out how to release the wire terminals, but it was a two-minute job to put it back together after that.
    The key to success for me was getting plenty of light in there (full sun). There's an awful lot of dark in that relay box.
    Brilliant solution OP, thanks!
