Fog Lights are for...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoQC1, Feb 12, 2023.
  1. Feb 12, 2023 at 6:49 PM
    #41
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    At the time I had that thing I drove a pretty sketchy mountain and you needed it for viability early in the morning. I always dipped it when oncoming traffic appeared.
    50Buck and Squirt[QUOTED] like this.
  2. Feb 12, 2023 at 6:51 PM
    #42
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Well that's good. :thumbsup:
    I always wanted to put one in the hood scoop of my old truck just for driving on country roads at night but never went through with it
    Delta09[QUOTED] and 50Buck like this.
  3. Feb 12, 2023 at 6:53 PM
    #43
    eurowner
    eurowner Duke Sky
    Scoty
  4. Feb 12, 2023 at 6:55 PM
    #44
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    ToyoTaco25, oconnor, Chew and 2 others like this.
  5. Feb 12, 2023 at 6:57 PM
    #45
    eurowner
    eurowner Duke Sky
    Scoty
    o_O
    J Williams, Travlr, po35042 and 4 others like this.
  6. Feb 12, 2023 at 6:58 PM
    #46
    InThePlains
    InThePlains Well-Known Member
    I tried that route, but I couldn't bring myself doing it to other people. Bought OEM LED from TW instead.
    Glare-O-Matic.
  7. Feb 12, 2023 at 6:58 PM
    #47
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    All this time I thought I had driving lights. I might even look to see if they look yellow.
  8. Feb 12, 2023 at 7:02 PM
    #48
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    What a $hitty thread.
  9. Feb 12, 2023 at 7:05 PM
    #49
    TacoQC1
    TacoQC1 [OP] Well-Known Member
    TRD Off Road
    My rant did sound Karenish, my bad! I was stuck in traffic last week and some fellow taco owner was blinding me and a poor Honda Civic driver directly in front and I’m sure others. It was like 5:20pm with plenty of daylight out. I get it I have aftermarket amber led fogs and I love how they look when turned on.
    raveseer, wrightme43 and 50Buck like this.
  10. Feb 12, 2023 at 7:08 PM
    #50
    10thMTNgrunt
    2013 TRD Sport
    You’re good OP, we’ve all been bent over something similar from time to time, just having a bit of fun with the choice of topic.
    Chew likes this.
  11. Feb 12, 2023 at 7:42 PM
    #51
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    FIFY
  12. Feb 12, 2023 at 7:45 PM
    #52
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't disagree with the OP. I can't say that it bothers me if others do it. I've never had a problem with any of the better headlights used on other vehicles. If you like the look, go for it. Most won't admit it, but looking cool is the main reason they do it. Sorta like running Raptor lights on a non-Raptor truck.
    Running fog lights when it isn't foggy just seems silly to me. I've tried it and the only time it helps is at night and in THICK fog. And then only when driven very slowly. I've been in fog so thick I had to roll the window down, hang my head out and look for the edge of the road. My fog lights made a difference in that. No other time. Fog lights only project 10-15' ahead and to the side. That isn't going to illuminate anything far enough in advance to be of any use at normal highway speeds.
    blu92in99 likes this.
  13. Feb 12, 2023 at 7:48 PM
    #53
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Don't look directly into the oncoming traffic lights.
    Or does ONE put your high beams on to indicate to the oncoming vehicle that their lights are too bright?
  14. Feb 12, 2023 at 7:53 PM
    #54
    50Buck
    Local LEOs like to tag people for flashing because it's not legal here, so I won't flash other drivers unless they flash me first thinking I'm on brights. I generally kept my headlights properly aimed in the Tundra because I could do it from the cab on the go, but losing that feature in the downsize... I might forget once I get stuff loaded in the bed or hook up the trailer.
  15. Feb 12, 2023 at 7:56 PM
    #55
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Well it appears that you've hit a cord with this thread and it's pretty obvious why civilization is in the shitter. But thanks for the effort.
  16. Feb 12, 2023 at 7:57 PM
    #56
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Whenever I want cause the Diode Dymamics SS3 MAX are bright AF!!!
    Taco22trdor and MGMDesertTaco like this.
  17. Feb 12, 2023 at 7:58 PM
    #57
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    I wondered why I'm always getting flashed...
    Delta09 likes this.
  18. Feb 12, 2023 at 7:58 PM
    #58
    50Buck
    Is it because people are too sensitive and entitled or because they are too selfish and entitled? Either could be "obvious" from this threads posts.
  19. Feb 12, 2023 at 7:58 PM
    #59
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    @50Buck
    I have driving experience in CA, TX and DE...no experience in Wyoming.
    Delaware is a Unrban/Rural state. Most every truck owner has fogs because we don't have street lights unless on a main road.
    It's an acceptable circumstance to driving here.
    It's based on location and I'm not here to argue/dispute the use of Fogs on state roads.
  20. Feb 12, 2023 at 8:00 PM
    #60
    50Buck
    My statement about legality was about flashing brights. Nothing to do with fogs. So far as I know in the US there's nothing on the books about it. I know in the UK they have laws and give tickets for improper fog light use, but that's across a really big pond. Has no bearing here. We rebelled for a reason.
