fog lights behind grille
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyota03, Jan 22, 2012.
  1. Jan 22, 2012 at 12:35 PM
    scyota03
    scyota03 [OP] Well-Known Member
    sumter,southcarolina
    03 trd prerunner
    3 inch coil spiring spacer, front bull bar
    do i gotta buy some kind of mount to mount fog lights behind my grille?
  2. Jan 22, 2012 at 12:45 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    either buy a light bar from a member here timsxr or fab one up yourself at home depot.. there are threads :)
    and you would be adding offroad lights.. hella, lightforce, KC, etc.... not your stock OEM fog lights.. hah
  3. Jan 22, 2012 at 12:57 PM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
  4. Jan 22, 2012 at 1:11 PM
    whatatoy
    whatatoy Galt/Rearden 2012
    SO CAL
    I like it
    This truck is a work truck - not a lot of fancy mod's here, but it's getting the job done!
  5. Jan 22, 2012 at 1:14 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    ^ I did mine similar to that link above but since your a first gen it will be slightly different, i went and bought some aluminum angle iron and cut 2 4" or so pieces then drilled 2 holes in it to bilt it to the radiator support bar, then drilled a hole for the light to mount to on the bottom of the angle iron...It will be shaped like this against the radiator support ( J ) with the light on the bottom..but you will also have to take into account how big your lights are, mine are 7" so i just figured where i wanted it behind the grill and marked before i drilled holes in the radiator support to bolt the bracket up. I will take some pics if i think about it next time i go out side
  6. Jan 22, 2012 at 1:53 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
  7. Jan 22, 2012 at 2:42 PM
    whatatoy
    SO CAL
    I like it
