Fog lights draining battery?
Discussion in 'Lighting' started by kevine, Aug 19, 2009.
  1. Aug 19, 2009 at 9:20 PM
    kevine
    kevine [OP] Well-Known Member
    Valencia, CA
    Tacoma Pre-Runner
    tinted windows
    I just installed fog lights and per the instructions, I ran the red/hot wire directly to the battery, rather than through the light relay/circuit. I keep them off when not in use, but will having them wired straight to the battery cause any drainage on the battery, even when they are off (with car off too)?:confused:
  2. Aug 19, 2009 at 9:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If they are not on, there should be no drain.
  3. Aug 22, 2009 at 7:15 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    When I first followed the directions I ran it straight off the battery. I realized the light on the on/off switch would stay on which made me nervous. I suppose if yours stayed on too that little light could slowly drain it?
  4. Aug 22, 2009 at 8:20 AM
    kevine
    Valencia, CA
    Tacoma Pre-Runner
    tinted windows
    Thanks Chris, for the boost in my confidence. Since it's a toggle switch, I'm assuming it cuts off power thus, no drain. As far as the switch staying on, it's pretty secure in the on/off position, so I'm not too worried. I only wish the switch lit up when on, that way, when I'm getting out of my truck, I can see if it's accidentally left on. Oh well, I'll just have to be careful.
  5. Aug 22, 2009 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you want, you can run a lit switch with a relay, getting its power from the marker lights, that way, when the headlights or marker light are turned on, the switch will illuminate, and allow use if the off road lights. AND, if you forget to turn them off, they will turn off with the headlights, preventing any battery drain. :)
  6. Aug 22, 2009 at 9:00 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I would try to do what Chris stated, this way you know off is off.
