Fog lights fill with water
Discussion in 'Lighting' started by Fisherman983, Dec 17, 2018.
  1. Dec 17, 2018 at 11:51 AM
    Fisherman983
    Fisherman983 [OP] Well-Known Member
    Alex
    2013 Tacoma Trd sport
    None yet.
    Decided to give my recently purchased gen 2 its first bath.
    I noticed that the fog lights as the now full of water. Looks like the previous owner cut th inner plastic fender wells.
    Other than replacing the inner fender, what can I do to keep water out of my fog lights for now.
  2. Dec 17, 2018 at 11:52 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You can take them apart and clean and dry them really well then seal them with silicone.
    whatstcp likes this.
  3. Dec 17, 2018 at 11:54 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If the fog lights are getting water inside, then the housings are leaking. Simple but expensive option is to replace the housings/lights. You may be able to reglue the light housings, however thats hit or miss.
  4. Dec 17, 2018 at 5:14 PM
    Fisherman983
    Alex
    None yet.
    maybe a stupid question, but best/cheapest place to purchase new housing?
    vendors on this site?
    high quality after market options?
  5. Dec 17, 2018 at 5:33 PM
    rnish
    Tacoma 2nd gen
    crashnburn80 and Key-Rei like this.
  6. Dec 17, 2018 at 10:10 PM
    Fisherman983
    Alex
    None yet.
    How much better off would I be to get a set of the KC hi lite replacements over getting an oem replacement and putting in a set of vled bulbs?
    I have no experience with the vled bulbs but from what I can tell they are quite a bit brighter?
  7. Dec 17, 2018 at 10:13 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Where are you located?
  8. Dec 18, 2018 at 4:35 AM
    Fisherman983
    Alex
    None yet.
    Toledo, oregon
  9. Dec 18, 2018 at 4:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Needs more blinker fluid
    o0oSHADOWo0o likes this.
  10. Dec 18, 2018 at 4:48 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    What type of bulbs are you using? When I replaced my fog light bulbs with cheap led bulbs, they always fogged up. When I went back to quality halogen bulbs, they wouldn't fog. The seals on the led bulbs were junk. I replaced mine with the KC G4's, so I've got a set of factory housings if you're interested.
    crashnburn80 likes this.
  11. Dec 18, 2018 at 5:26 AM
    Fisherman983
    Alex
    None yet.
    Just bought the truck, and it has an led bulb inside, I have no idea what brand/model. But I do know they are pretty much worthless as far as lumen output.
    The aftermarket bulb could be the issue in itself?
    I do know that the end goal is to replace the entire housing/set up for some BD squadron pro's. That's just not entirely financially feasible right now. At this point i want them to function and not suck.
    What's the going rate for a set of housings? I'm new to Tacomas and parts prices
  12. Dec 18, 2018 at 6:36 AM
    308savage
    Adam
    East Tennessee
    The led bulbs I had used a silicone gasket that was very soft and flexible where the halogens had what looked like a stiffer red rubber gasket. If it was me, I'd buy some decent halogen bulbs and try those first before buying housings.
  13. Dec 18, 2018 at 7:49 AM
    gravyboat
    Jon
    Olympia
    Ok nevermind. I was gonna say if you’re near me I’d meet up and sell you mine but that’s a bit far from me. Good luck, man.
  14. Dec 30, 2018 at 1:14 PM
    308savage
    Adam
    East Tennessee
    Did you get your lights fixed?
  15. Dec 30, 2018 at 4:21 PM
    Fisherman983
    Alex
    None yet.
    Not yet, ordered parts, still waiting.
  16. Dec 31, 2018 at 2:37 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Be careful with claims that any particular bulb - particularly LEDs bulbs - are "brighter." The first problem with most aftermarket LED replacement bulbs is that they flat out don't last very long - despite wild claims of durability. Second, slapping an LED bulb into a housing designed for a halogen bulb will almost always decrease the performance of the light. The following post will give you more information on that subject than I could ever type here.
    https://www.tacomaworld.com/threads...alogen-reflectors.454371/page-5#post-17731252
    Finally, beware claims of "brightness" as measured by Lumen output. These claims are almost always based on theoretical output as opposed to actual output. Want to guess which one is always lower?
    Do yourself a favor and buy a replacement set of LED pods as reviewed and posted by crashnburn80. (That link was already shared.) I have a set of the winning KC pods as shown in that post and they're absolutely awesome. Beware non-DOT compliant pods because although they may be bright, you'll also piss off oncoming drivers due to their lack of beam discipline.
  17. Dec 31, 2018 at 4:32 PM
    Fisherman983
    Alex
    None yet.
    I went thru that thread a couple times trying to soak up as much info as I could.
    I ended up ordering a set of BD squadron pros. Waiting on delivery to instal.. when I can afford a set of $1500 retrofits for my headlights I'll swap those out as well.
  18. Dec 31, 2018 at 4:39 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sounds like your blinker fluid was low or empty. After you started washing you had actually started refilling them. I am suprised your blinkers were working being so low on blinker fluid.
  19. Dec 31, 2018 at 7:03 PM
    Too Stroked
    Tom
    Those are great lights, but not DOT legal. Unfortunately, I think you'll find that they tick off oncoming drivers pretty well.
