Fog Lights for SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigE4115, Mar 8, 2019.
  1. Mar 8, 2019 at 6:19 PM
    BigE4115
    BigE4115 [OP] Member
    Ethan
    Pittsburgh
    2016 Silver 4WD Access Cab SR
    Looking to buy fog lights for my 2016 SR.. not looking for crazy expensive but still want quality. Also I’m not sure what I need to buy to have these fit because there currently isn’t a housing for the bulb in the SR I have. If anybody could point me in the right directions I would appreciate it!
  2. Mar 8, 2019 at 6:21 PM
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    Do you want stock ones? I have a set I’ll sell
  3. Mar 8, 2019 at 6:22 PM
    Jethro 2.0
    Jethro 2.0 Well-Known Member
    New Hampshire
    2017 MGM SR5
    lax22, RocTaco and OilTruck like this.
  4. Mar 8, 2019 at 6:36 PM
    OilTruck
    OilTruck Well-Known Member
    Peter
    Katy, TX
    2016 SR Stick 4x4 Access Utility
    I know it left me smiling and satisfied. No seriously, i bought a cheap ebay kit with a harness, lights, switch etc. and then realized I needed the OEM bezels, an additional switch plate, and a better switch.
    But eventually I got a dash switch working with the dogs I installed. At some point in the future I'll replace the reflectors with better quality reflectors, but for now it helps considerably.
  5. Mar 8, 2019 at 6:37 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    jeffmansion and OilTruck like this.
  6. Mar 8, 2019 at 6:57 PM
    BigE4115
    Ethan
    Pittsburgh
    I appreciate the help fellas. Started reading through that thread and I’m thinking that’s a little above my pay grade of technical knowledge. This is the first truck I’ve ever really started to work on so a lot of that thread went right over my head lol
    SilverBulletII likes this.
  7. Mar 8, 2019 at 7:16 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I felt the same way, but it really isn't bad. Just read that thread like 10 more times, then order your parts, and follow his instructions step by step as you do it and you'll be fine.
    I use mine all the time, super happy I did it.
  8. Mar 9, 2019 at 4:43 AM
    lax22
    lax22 Well-Known Member
    3rd Gen Tacoma
    Mibtown front hitch
    Check the for sale section for lights and bezels then get the grill harness from eBay. From there you can choose a dash switch or swapping the stalk. I swapped the stalk and was happy I did since I didn’t want to hack up the factory harness. I bought all the parts new except the fog lights and bezels the thread referenced was a huge help.
  9. Mar 9, 2019 at 5:13 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    2 led mag lights and some zip ties. Done. :thumbsup:
    AxisCab likes this.
  10. Mar 9, 2019 at 6:12 AM
    OilTruck
    Peter
    Katy, TX
    What do you mean hack up the harness? Not saying you're wrong, just genuinely curious/confused. The way I did it with a dash switch, the fog lights are independent of the truck electronics except for a (+) battery lead. Harness has built-in independent fuse. I like the ability to keep the dogs on with my highbeams.
  11. Mar 9, 2019 at 8:47 AM
    lax22
    3rd Gen Tacoma
    Mibtown front hitch
    If you wanted to use the factory wiring for the fog lights and the truck was equipped with the dash wiring going to the headlight stalk, you can tap into that wire for a dash switch or just upgrade the stalk to the one with the integrated fog switch. I opted to go with the factory plug and play option since my SR had the dash wiring. All I needed to activate it was the relay and the proper fog light headlight stalk.
  12. Mar 11, 2019 at 1:09 PM
    BigE4115
    Ethan
    Pittsburgh
    So I was reading into that thread and I was curious if the wiring will be the same for any fog light I buy and if that still flies on the 3rd gen tacos. I would like to buy different lights than the TRDOR ones but was hoping that wiring is the same all the way down to the fog light then I can plug any fog light into the harness.
  13. Mar 11, 2019 at 3:01 PM
    Jethro 2.0
    New Hampshire
    2017 MGM SR5
    What lights were you looking to get? Some have plug and play options offered with them. For instance I put baja design squadron sports in my fog pockets and they came with the mounting hardware and electrical connections that would interface with the stock wiring. They are SUPER bright so it was my plan all along to not run them as fogs, rather to run them as auxiliary high beams (using a relay i tapped the high beam signal to be the trigger wire).
