Fog lights no worky
Discussion in 'Lighting' started by TxStVanWilder, Sep 16, 2023.
  1. Sep 16, 2023 at 5:56 PM
    TxStVanWilder
    TxStVanWilder [OP] The Pale Horse
    Tx
    2013 TRD Sport
    2013 Tacoma Sport. I have KC G4 fog lights. Installed the fog light anytime mod years ago. A couple months ago I thought I noticed driving at dusk that my fog lights came on as I was turning through the neighborhood. Now typically I keep them on at all ties and don’t even mess with the button.
    Now a few weeks later I noticed the lights are no longer on. I replaced the fog light fuse under the hood with no luck. Thinking it might be the switch or possibly something else.
    Hoping someone has dealt with something similar to lead me in the correct direction.
  2. Sep 17, 2023 at 9:50 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Do you have a multimeter, and can you pull the fog light relay and check to see if you are getting voltage?
  3. Jan 18, 2024 at 12:49 PM
    TxStVanWilder
    Tx
    2013 TRD Sport
    So I finally got a meter and some free time today. It’s getting power in all the right places. I’m wondering if it’s the switch or maybe a ground to the fog light harness (if that’s even a thing)
  4. Jan 18, 2024 at 12:54 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Sound like a ground to me. I’ve got the same setup with the factory switch. :notsure:
  5. Jan 18, 2024 at 1:25 PM
    TxStVanWilder
    Tx
    2013 TRD Sport
    Google isn’t helping, is there a specific ground for the fog lights?
  6. Jan 18, 2024 at 1:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What did your meter say when you went from both terminals of the fog light connecter?
    You did have the low beams on, and not the high beams, Correct?
    The fogs only come on with the Low beams, the power is cut when switch to High beams.
    A test light would be so much more helpful here.
