Fog lights on = poor radio reception
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Sep 29, 2010.
  1. Sep 29, 2010 at 9:31 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    There are times when I cannot get a decent signal on my radio - even though I am accessing very strong, local stations. Well, today, I noticed the problem is substantially worse when I turn my fog lights on.
    I do have some modifications on my fogs:
    fog's always on (bypass wire added to the top of the fuse box)
    HID's
    Just thought it was odd. Not really looking for a solution - I generall use my MP3 or Pandora (awesome). If I'm listening to the radio, I can just shut off my fogs.
    Could it be possible I am not grounded correctly? Or is it because I am grounded that its causing the problem? Those HID's use a lot of juice.
  2. Sep 29, 2010 at 9:34 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    My HIDs affected my radio signal too. alot of static. maybe its the frequency the hids emit that interfere with the radio
  3. Sep 30, 2010 at 5:48 PM
    timmo
    timmo Well-Known Member
    Tim
    OKC
    2010 doble cab 4wd sr5-silver
    i hate to say it but it looks like you're gonna have to "harden" your entire vehicle against electromagnetic interference. the r&d is gonna cost you but at least the payoff will be minimal!
  4. Sep 30, 2010 at 6:09 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    my old set of HID fogs caused my radio to lose like 30% reception. New kit on the way, I'll see if it will do the same.
  5. Sep 30, 2010 at 6:11 PM
    AK27
    AK27 Well-Known Member
    my radio was fuzzy for awhile and didnt know why the fogs affected it. i had a bulb out :eek:
  6. Sep 30, 2010 at 8:01 PM
    Veccster
    Eric
    2020 Pro
    Great work, detective! Some of that would be over my head but I get the gist of it. My HID headlights have no effect on the radio reception. So it has to be the grounding on the fogs. This weekend, I'll climb under there and check the wires. I'll also try moving some wires around to see if something is just too close and causing the interference.
    I'm also getting a new factory radio next week because the volume dial sporadically works - a well-reported problem.
    Thanks again and I'll be sure to post any findings during my investigations. I'm not going to start ripping apart my electrical system because the problem is minimal. But its worth a quick look.
    They definitely don't have an effect on my iheart radio app that I play on my Droid phone. Just hook it to my aux port and I'm set. Reception is crystal clear and never cuts out.
  7. Sep 30, 2010 at 8:18 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    FYI
    True HID light bulbs do not have filaments. It is an arc going through a gas (fluorescent type lighting)... Depending on frequency (brightness) there are always stray radio waves. Alot of HID fogs and headlights are not always true HID. If there is a filament the are not HID but are called HID because of High light discharge.
    "Fake" HIDs and one that run on a lower/higher frequency than the radio are not going to interfere with the radio...
    Being a service engineer working on imaging equipment, RF interference is an ongoing battle
  8. Sep 30, 2010 at 8:53 PM
    supralight
    Dan
    Earth
    So as I understand, my HID's were ''fake'' if they were causing interferences?
  9. Sep 30, 2010 at 9:03 PM
    Yoytoda
    Roland
    completely stock
    "fake" HIDs or ones that run on a higher or lower frequency DO NOT cause interference...
    read the post again...
  10. Oct 1, 2010 at 6:16 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    HIDs are the cause. They do it on my Taco with my Morimoto retrofits. Did it on my 07 Civic Si sedan with retrofits. Did it on my daughters Altima. This is a known issue with aftermarket HID ballasts. Factory HIDs are properly shielded to avoid this.
  11. Oct 1, 2010 at 6:36 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    It would seem to me that the very high voltage spikes created by an HID ballast would introduce a lot of noise into the electrical system of the car thus affecting the operation of the radio and any other audio equipment. It can't be good for the car.
    Also, just think about the hum and static you get sometimes when driving underneath power lines. This is only 60hz, nowhere near the frequencies of a radio.
  12. Oct 1, 2010 at 7:32 AM
    Yoytoda
    Roland
    completely stock
    The ballast is just a pulsing step up transformer. It does not hurt the electronics in the car. It is not interfering with anything. It just emits waves that the antena picks up. It's like have your own personal radio station that over powers any other station because it's so close to you.
    The reason you can here power lines is because 60Hz is audible. You can not hear the higher frequency of HIDs but that does not mean it will harm anything.
    Benefits I have at my job allow me to see RF. Ballasts like fluerecent lighting, cannot be used in an MRI room. They release a ton of "noise" which will corrupt an image... Just like it would corrupt a radio signal if at the same signal of radio waves. It will not harm any other electronics.
    Another way to put it.... The noise from the ballast isn't hurting the radio. The radio is just recieving those waves and playing the sound through your speakers because, to the radio, that is the station
  13. Oct 2, 2010 at 10:24 AM
    Yoytoda
    Roland
    completely stock
    What frequency is your ballast producing? Your car radio can pick up alot more than you would think... the "range" of FM is 87.5-108 Mhz. A CB is only 27Mhz and my radio picks that up when i use it and it is out of the "range".
    Most people with HIDs have the reception problem. There are a few companies that have "smart RF Ballasts" which are shielded.
    A dirty ground is possible but i dont think its likely. to avoid a dirty ground run the ground of the HIDs directly to the battery so if there is power from the ballast "dirtying" the ground, grounding to the source will clean the rest of the ground plain.
  14. Oct 2, 2010 at 10:33 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I just got "geeked" out with all this bestbuy talk -.-
