Fog lights on with DRL's
Discussion in 'Lighting' started by SURFTACO, Oct 20, 2009.
  1. Oct 20, 2009 at 2:44 PM
    SURFTACO
    SURFTACO [OP] Well-Known Member
    New Jersey
    09 TRD SPORT
    3'' Lift: Bilstein 5100’s, SPC UCAs, All Pro 3” leaf packs, Bilstein 5125’s, Kenda 33X10.5R17 Tires Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover Cali Raised Ditch Lights Snorkel
    I was interested in finding out if others are configuring there lighting so that the fog lights are on while the daytime running lights are working. If so, whats the best way to getting them to work? thanks
  2. Oct 20, 2009 at 3:39 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
  3. Oct 20, 2009 at 4:17 PM
    SURFTACO
    New Jersey
    09 TRD SPORT
    Thanks man. Ill check it out.
  4. Oct 21, 2009 at 5:31 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
  5. Oct 25, 2009 at 6:05 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I wouldn't try to jump the fogs off of the DRLs....even with a relay, because the DRLs are also your front turn signals. Depending on which side you use has the trigger for the relay, your fogs will blink with your turn signals.
    If you already have factory fogs, do the mod in the link the fellas gave you. If you're adding fogs, then just use the parking lamp circuit to trigger the relay. This is what I did for my base model. So if I want to, I can run my fogs and DRLs together simply by turing on my parking lamps.
