Fog Lights on with Parking Lights??
Discussion in 'Technical Chat' started by MakoTaco, Sep 11, 2010.
  1. Sep 11, 2010 at 7:26 PM
    MakoTaco
    MakoTaco [OP] New Member
    Sebastian, FL
    '10 Tacoma Sport 4x4
    Wanting to re-wire my factory fogs to come on with the parking lights, rather than ONLY on when the headlights are on. Is there an easy way to do so? Wire color, etc. would be helpful. Thanks! :mudding:
  2. Apr 23, 2022 at 12:10 PM
    gdolloway
    gdolloway Member
    Garrett
    15 access cab trd 6sp
    To come!!
    Was nobody able to figure this out?
  3. Apr 23, 2022 at 3:37 PM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    What year is your truck? Idk for 3rd gens but on 2nd gens there is a bypass you can do so you can use your fogs anytime with the switch. Just look up anytime fogs on the 2nd gen side. There are a few different ways of doing it. The way I did was bend one of the relay tabs and ran a jumper wire. I have had this for 5 years on my truck. No issues what so ever.
    Key-Rei likes this.
  4. Apr 23, 2022 at 3:40 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Just FYI the reason the fog lights only work with the low beams is due to some DOT/NHTSA laws but if you search "fog lights anytime mod" you'll find what you're looking for ish.
    I don't know of a plug and play easily reversible way to have them automatically come on with the parking lights but having them on a physical switch and able to turn on whenever you want them is a great alternative.
