Fog Lights! Stupid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by superdave, May 4, 2011.
  1. May 4, 2011 at 7:22 PM
    superdave
    superdave [OP] Active Member
    Dave
    St. Louis, Mo
    TRD Sport
    Camper Shell
    2010 Tacoma
    Aren't fog lights mounted low on a vehicle so it will cut the glare back to the driver in a fog or snow situation? If so, why do the fog lights only come on on my 2010 Tacoma when the higher mounted low beams are on? It's unsafe in the fog. This is just common sense. If they came on with only the amber marker lights, it would make more sense, cut the glare back at the driver, and add to the safety which is the idea of the fog lights in the first place......
    Engineered right? I think not.
  2. May 5, 2011 at 3:55 AM
    lwszabo
    lwszabo Well-Known Member
    Concord NC
    2018 SR double cab
    toyota dark satin alloy wheel Tint OEM bed mat
    Stock foglights are for looks. People want them for the looks!
  3. May 5, 2011 at 5:25 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    They are? :confused:
    Call me crazy, but I want them to cast more light in front and to the sides of me.
  4. May 5, 2011 at 5:29 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
  5. May 5, 2011 at 5:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Never had an issue or felt unsafe using the low beams with the fog lights in heavy fog or snow... That's why they ONLY come on with the low beams. If it's dark, the fogs don't produce enough light to drive with in my opinion so I think it was engineered just fine.
  6. May 5, 2011 at 7:28 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Agreed
  7. May 5, 2011 at 8:24 AM
    Pugga
    Massachusetts
    I agree that fogs should be close to the ground but if they do not produce enough light to see where you're going then it's useless to have them on without the headlights. They're there to suppliment the headlights, not replace them when it's foggy. I've found the headlights when on low beam to be aimed down enough so I don't get blinded in snow or fog.
    They work for snow the same way they work for fog. If you have high mounted lights in snow, it reflects back at you and blinds you so having the low mounted lights work well.
  8. May 5, 2011 at 8:27 AM
    OZ-T
    Peter North
    British Columbia
    Agreed
  9. May 5, 2011 at 8:31 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
  10. May 5, 2011 at 9:31 AM
    Pugga
    Massachusetts
    Yes, that would be nice and if they were bright enough to drive with I'd join your side of the argument and say they should come on without the headlights.
  11. May 5, 2011 at 9:32 AM
    Pugga
    Massachusetts
    :confused:
    Everyone's playing nice in the sandbox
  12. May 5, 2011 at 9:35 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    if u want them one without turning one ur headlights, then just do the fog light mod...5 mins or less and ur done lol :thumbsup:
  13. May 5, 2011 at 9:40 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah just do the FLM and do what you want with them after that.
  14. May 5, 2011 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Niburu
  15. May 5, 2011 at 9:44 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    There is a differance between a fog light and a driving light. Its all about the COLOR. Sorry bad color yellow. ITS ALL ABOUT THE COLOR!
    We do not have fog light on our trucks unless you change the lense color. White means driving light. Yellow means fog/snow conditions.
  16. May 5, 2011 at 9:52 AM
    OZ-T
    Peter North
    British Columbia
    Wrong
    And it's colour
  17. May 5, 2011 at 9:58 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Glad your here to clear this up !!!!
  18. May 5, 2011 at 9:58 AM
    OZ-T
    Peter North
    British Columbia
    You're
  19. May 5, 2011 at 9:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    SO you can spell that right, but you fuck up "color"?
  20. May 5, 2011 at 10:01 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Best answer so far.
