Fog lights wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orlando roofer, Feb 22, 2020.
  1. Feb 22, 2020 at 5:48 PM
    Orlando roofer
    Orlando roofer [OP] '15 Prerunner i4 2.7 DC SB RWD AT
    Sean
    '15 Prerunner i4 2.7 DC SB Auto
    Hi,
    My base '15 4-cyl prerunner didn't came with factory fog lights.
    If i want to do factory like switch - is it prewired for fog lights, relay, and wiring?
    Some net article say its prewired for 6-cyl but not for 4-cyl for 2nd gen.
    Any recommendations?
    Thank you!
  2. Feb 22, 2020 at 8:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would almost guarantee you are not prewired on a base 4 cyl prerunner.
    My SR5 2012 Prerunner wasn't either.
  3. Feb 22, 2020 at 8:17 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Run fused power from the battery to a relay, then a fused ignition power from a switch of your choosing to the relay, and then a power to your fogs off of the relay. Then ground the relay and your fog lights.
    you could use a factory style switch to do this but it would probably be a pain to use a entire factory harness. Better off making your own if you have any wiring experience.
    Orlando roofer[OP] likes this.
