Fog Lights
Discussion in 'Lighting' started by tanktodd, Aug 6, 2009.
  1. Aug 6, 2009 at 6:40 AM
    tanktodd
    tanktodd [OP] Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    Can anyone tell me how to get my fog lights on with only the parking lights. My fogs won't work unless the headlights are on..thanks
  2. Aug 6, 2009 at 6:47 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Check the "Mods & Tutorials" tab at top. I think there is a "daytime running lights" mod. in there.:)
  3. Aug 6, 2009 at 7:07 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Try that search thingy up top o' the page.
  4. Aug 6, 2009 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You want to do the Fog Light on Anytime mod:
    Several ways to do this, but this one was the easiest for me, and I haven't had them come on 4-hours after turning the ignition off like other methods cause. Apparently at least one other method ties into some ignition or emissions circuit that turns on 4 hours after the truck is turned off to deal with emissions so the fogs come on for a few minutes. I parked in front of my living room window for a year after doing this and never saw them come on once so.....
    Tools/items needed:
    • wire stripper
    • 1 quick splice
    • 1 female blade connector
    • 6" of wire
    • drill/bit same diameter as wire
    • shrink tube/electrical tape to reinforce crimp connection (optional)
    1. Locate the green wire on the plug in the pic
    2. splice into it
    3. run the wire to the fog light relay through a hole to keep it low and not hit the cover
    4. crimp on the female blade connector onto the wire
    5. pull the fog relay and bend the terminal in the pic to the side
    6. put the female blade connector onto the bent terminal on the fog relay
    7. replace fog relay
  5. Feb 24, 2010 at 9:56 AM
    bruce1271
    bruce1271 Well-Known Member
    Chris, What is the green wire? Is it always on power? What are we bypassing on the relay since one terminal is not plugged in now?
  6. Feb 24, 2010 at 2:20 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    Bypassing nothing. The switch in the dash switches the ground for the trigger side of the relay on and off. Your just giving the trigger side a new 12v power source. The relay only needs about 1/10th of an amp to operate so you can get that trigger voltage almost anywhere...... RON
  7. Feb 26, 2010 at 7:49 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    Is this mod working with the 2010 models ?
  8. Feb 26, 2010 at 9:34 AM
    dog tired
    NE Ohio
    So could you run this straight to the pos on the battery and avoid splicing into wires ?
  9. Feb 26, 2010 at 9:45 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
