Fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beetlejuice1502, Jul 26, 2022.
  1. Jul 26, 2022 at 4:38 PM
    Beetlejuice1502
    Beetlejuice1502 [OP] Member
    2010 TRD pre runner
    My fog lights on my 2010 tacoma won't work. Not the fuse or the bulbs. I'm going to check the switch next. Anything else I should look for before I have to follow the wires to find a cut or burnt wire?
  2. Jul 26, 2022 at 4:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The headlights have to be ON and set to LOW.
    Have you checked that?
  3. Jul 26, 2022 at 7:29 PM
    Swb_05
    Swb_05 Member
    Casey
    2005 Speedway Blue TRD OR
    X2
    I had kinda a brainfart moment soon after I got my truck. For the life of me I couldn't get the fogs to turn on, went through the normal checklist, nothing. Flipped the Hi/lo switch and baam! Fogs worked. Ended up doing the fog light anytime mod so I could run fogs and park lights.
    Good luck figuring out your problem.
    TnShooter[QUOTED] likes this.
