Fog lights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PooTaco, Dec 20, 2024.
  1. Dec 28, 2024 at 7:23 PM
    #41
    PooTaco
    PooTaco [OP] Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    Now I'm back to looking for a good harness with relay...
  2. Dec 29, 2024 at 2:26 PM
    #42
    PooTaco
    Utah
  3. Dec 29, 2024 at 3:53 PM
    #43
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Your chosen lights do not have directly compatible connectors with this harness, i.e. not plug and play. I would think the manufacturer would have a harness that would be. Talk to them, I’m sure they would help.
  4. Dec 29, 2024 at 4:20 PM
    #44
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    We don’t have a harness to add factory fitment fog lights to a no-fog truck, sadly. Do you want independent control of them? If so, that harness you posted would suffice, but the output connector type is not H11, so it would need to be modified for those.
    If you don’t want/need independent switching, you can split off the stock low beam circuit directly and they’ll just be on when low beams are on. However, it may require a relay setup if the load is too much. I can’t say I’ve done this specific setup so I’m not sure if it’s too much of a load or not. Also, the low beams may not shut off when you turn on the high beams, which is when the fogs should shut off so you can better see in the distance too
  5. Dec 29, 2024 at 5:33 PM
    #45
    PooTaco
    Utah
    Independent.
    It looks like a morimoto fogs come with h11 but they are not connected, wouldn't a female 2pin deutsch connector work?
    https://www.morimotohid.com/deutsch-connectors-DEUTSCH?quantity=1
  6. Dec 29, 2024 at 9:31 PM
    #46
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    do they come adjusted close to the oems or did you have to adjust them?
  7. Dec 29, 2024 at 10:33 PM
    #47
    SGJarrod
    SGJarrod Jester of the Degen...
    STL
    23 TRD OR DCLB, Blue Crush
    I got a sticker and some cool valve stem caps...
    Have to adjust a bit... screwdriver and masking tape. I have faith in u!
    PooTaco[OP] and RIX TUX[QUOTED] like this.
  8. Dec 29, 2024 at 11:08 PM
    #48
    RIX TUX
    dang....they say plug and play
  9. Dec 30, 2024 at 2:59 AM
    #49
    SGJarrod
    STL
    And when I'm at work, I act like I give a shit about the retarded company I work for... the world is not as it seems. :cool:
  10. Dec 30, 2024 at 3:58 AM
    #50
    Jpockets
    Jpockets Well-Known Member
    john
    NY
    2023 Tacoma SR Acess cab 4x4
    Have you by any chance looked at the rough country foglight kit. it has everything to put fogs in a Sr. Not sure if you wanted white lights though, but you could add the yellow fil over the lens.https://www.roughcountry.com/product/tacoma-led-fog-light-kit-71095 And as far as I can tell the wiring harness would work, the only thing in the kit that has a issue is the switch.... it needs to be modded to fit, according to the reviews.
    PooTaco[OP] likes this.
  11. Dec 30, 2024 at 4:12 AM
    #51
    Jpockets
    john
    NY
  12. Dec 30, 2024 at 4:17 AM
    #52
    Jpockets
    john
    NY
    this one wouldnt work? https://www.morimotohid.com/morimoto-h9-hd-relay-harness?quantity=1
  13. Dec 30, 2024 at 10:39 AM
    #53
    PooTaco
    Utah
  14. Dec 30, 2024 at 10:46 AM
    #54
    TRSAndrew
    ATL
    PooTaco[QUOTED][OP] likes this.
  15. Dec 30, 2024 at 10:48 AM
    #55
    TRSAndrew
    ATL
  16. Dec 30, 2024 at 10:56 AM
    #56
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    I'm a cheap skate and with my 17 SR I didn't wanna buy a new harness from Toyota to install the Tacoma fog lights I picked up here on Taco World so I went to the junk yard and snagged the wiring from a Camry with the connections for $10 and used an aftermarket switch. The new harness was over $100 at the time. I got the LX chrome surrounds and new fog light take offs for $35.
  17. Dec 30, 2024 at 11:37 AM
    #57
    PooTaco
    Utah
    That's what I'm going to do.
    Now to see if the length of the harness works.
  18. Dec 30, 2024 at 11:56 AM
    #58
    Jpockets
    john
    NY
    Sounds like you could sell alot more foglights for sr tacomas if morimoto made a harness that was plug and play. I have been hunting for a harness as well, I like the evo+ fogs. But it has been a total hassle trying to find a harness to work, just like the OP of this thread.
    Pibbles99 and PooTaco[OP] like this.
  19. Dec 30, 2024 at 11:59 AM
    #59
    Jpockets
    john
    NY
    dont forget you need to source out the bezels, rock auto has them.... good luck to you.
  20. Dec 30, 2024 at 2:00 PM
    #60
    PooTaco
    Utah
    Agreed, it has been a lot of searching.
