Fog Switch Wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grammy, Jul 10, 2009.
  1. Jul 10, 2009 at 5:55 PM
    grammy
    grammy [OP] Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    I just installed factory fog light and a relay (adding this option to my truck). I am waiting on my switch, but being curious, I took out the blank where the fog light switch will go and there is nothing there. There is wiring leading to the other two blanks to the right of the fog space.
    The fog light wiring harness was behind the bumper and the lights clipped in no problem.
    I think wiring should be there for the switch, is it possible that it is behind one of the other blanks???
    The center blank is a 4 pin connector.
    Thanks
  2. Jul 10, 2009 at 10:15 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Yes, it's in one of the other banks. I checked the blank that the factory switch is located and the connector was not there. Got really worried, but then saw a connector in the next slot over. Plugged it in and bingo.
  3. Jul 11, 2009 at 4:02 AM
    grammy
    4x4 v6 X-Cab
    Good... Thank You.
