Fogged Windows
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mach428, Dec 22, 2023.
  1. Dec 22, 2023 at 8:23 AM
    Mach428
    Mach428 [OP] Well-Known Member
    Tom
    Ocala, Florida
    2016 Tacoma Sport Barcelona Red DCSB
    2016 Tacoma Sport 4 door is getting moisture inside the cab and actually condensing water droplets on the inside of the windshield. It doesn’t even have to rain; just the evening dew and temperature change. Has anyone experienced this?
  2. Dec 22, 2023 at 8:27 AM
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Door / windows seals probably. Fogged windows can be fixed with defogger
  3. Dec 22, 2023 at 8:36 AM
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    This kind of stuff would help maybe
    Mach428[OP] likes this.
  4. Dec 22, 2023 at 8:53 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Can get some Dri-Z-Air or something like it and stick it in the truck. Will suck the moisture outta the air.
    eurowner and Mach428[OP] like this.
  5. Dec 22, 2023 at 8:58 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Maybe it's just your local climate and humidity levels. Are you running A/C constantly? Without or without Recirculate on? I've encountered certain situations causing condensation on the inside of the windshield. My solution has been to turn on Windshield defrost OR open a window or 2 a crack to better move the air around the inside of the cab.
  6. Dec 22, 2023 at 9:14 AM
    Mach428
    Tom
    Ocala, Florida
    All good suggestions but I’m afraid it’s something else. I bought this new in Feb of 2016, so I know my truck and this just started. This isn’t just “fog” rather water droplets that have condensed on the glass interior. And there doesn’t appear to be any consistency.
  7. Dec 22, 2023 at 9:18 AM
    YF_Ryan
    Kent, WA
    Have you checked your carpeted floor everywhere? It's one way to check if water is getting in somewhere, cause, it obviously is. For my old truck (a chevy, not a taco), there was some front windshield drain that plugged and when it backed up it ran into the front passenger floorboard.
    RIX TUX and Chew like this.
  8. Dec 22, 2023 at 9:19 AM
    Mach428
    Tom
    Ocala, Florida
    you do raise some interesting conditions I haven’t thought of. My climate has had no effect on this issue. Meaning I had the truck under the same climate variances for almost 8 years. I’ll try a DampRid and see if it pulls moisture.
  9. Dec 22, 2023 at 9:20 AM
    Mach428
    Tom
    Ocala, Florida
    I have checked the carpet but not thoroughly. I’ll do that tomorrow and advise.
    All great advice guys. I appreciate it.
    WallyIAm and YF_Ryan[QUOTED] like this.
  10. Dec 22, 2023 at 9:51 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Check headliner for moisture as well. I know the sunroof drains can get clogged and back up, but I forget where exactly that leaks into the cab.
    I would check sunroof drains or roof rack mounting points (both if applicable) if headliner is wet and windshield cowl drains, a/c drain hose and windshield seal if the carpet under the dash is wet.
    You could also verify the drains at the bottom of your doors are clean and clear. I saw a post about those being blocked and a door filling up with water :eek:
    Chew, Mach428[OP] and YF_Ryan like this.
  11. Dec 22, 2023 at 10:53 AM
    Mach428
    Tom
    Ocala, Florida
    My truck doesn’t have a sunroof but good point about headliner. I’ll check.
    musicisevil likes this.
  12. Dec 22, 2023 at 11:19 AM
    eurowner
    eurowner Duke Sky
    Scoty
    When was the last time the cabin filter was replaced?
  13. Dec 22, 2023 at 11:24 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Maybe I missed it; was the cab mount 3rd brake light checked and/or replaced?
    It sounds like maybe something is letting water in, and the interior may not be drying out fully in between rains?
  14. Dec 22, 2023 at 11:24 AM
    Mach428
    Tom
    Ocala, Florida
    I replace them every spring.
  15. Dec 22, 2023 at 11:25 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Heater core in the cabin may be leaking ?
    WinterFalco and BUZZCUT like this.
  16. Dec 22, 2023 at 11:26 AM
    Mach428
    Tom
    Ocala, Florida
    I thought of that too. I replaced the third brake light two years ago. It’s the first thing I checked but it appears to be tightly sealed and everything is dry in the cubbies.
    musicisevil and Chew[QUOTED] like this.
  17. Dec 22, 2023 at 11:48 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Check the rubber door seals? Mine were loose from factory and leaking water for three years before I found out where it was leaking.
    Mach428[OP] and musicisevil like this.
  18. Dec 22, 2023 at 1:38 PM
    TedTRD
    TedTRD Well-Known Member
    Charles
    2023 Tacoma TRD
    As others have said, check for moisture inside the truck. Dealing with a similar problem with my daughter’s Audi Q3. They seem to have a systemic problem with leaking sun roofs.
  19. Dec 22, 2023 at 3:09 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    I had a similar sounding issue before my heater core failed in another vehicle
    WinterFalco likes this.
  20. Dec 23, 2023 at 8:47 AM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I had this problem with my 88 Mustang. Turned out to be a leaking heater core. Check the carpet on the passenger side. Good luck, I hope you get the issue resolved.
