foglight harness
Discussion in 'Lighting' started by c.morris89, Nov 16, 2010.
  1. Nov 16, 2010 at 9:48 AM
    c.morris89
    c.morris89 [OP] Well-Known Member
    Kingsport TN
    2021 PRO MGM 6MT
    A little
    Bought Spyder foglights from autoanything and it seems that my wiring harness has decided to die out on me. I called Spyder and they said that I would have to reorder the whole kit again just to get the harness. Anyone know of other places to get a cheap harness? Thanks in advance
  2. Nov 16, 2010 at 9:51 AM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    Make your own. It's pretty easy to do. Just buy a relay at the autopart store for like $4-5 and some wires.
  3. Nov 16, 2010 at 10:25 AM
    c.morris89
    Kingsport TN
    2021 PRO MGM 6MT
    A little
    Do they also sale the actual male end connectors that will connect to lights?
  4. Nov 16, 2010 at 10:34 AM
    Thucker
    Portland, OR
    Depends on the type of connector your lights use. If it's the typical round post style ones, then yes. You could always cut the plugs off your old harness and use them with the new harness.
  5. Dec 15, 2010 at 1:25 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    did u fix the problem OP?
    i was looking to get a set of fogs from spyder too,
    hope this doesnt happen to me too
  6. Dec 15, 2010 at 1:33 PM
    c.morris89
    Kingsport TN
    2021 PRO MGM 6MT
    A little
    Yep I got em fixed....it was a bad relay. Replaced that and everything works fine.
