Foglights are DEAD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crf69, Aug 4, 2019.
  1. Aug 4, 2019 at 6:38 AM
    crf69
    crf69 [OP] scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    My fogs have been dead in my 2006trdor for nearly 5 years now, i attribute it to my wiring job and now have condemned the whole wiring from the relay out to be done,
    i had piaa 4inch in my relentless bumper but they are in sad shape so looking to get another set or something like that, my ultimate question is what foglight kit is best these days for a direct throw in, or total bypass of stock system, for a quick install/fix?
    thanks tacomaworld!!!!!
  2. Aug 4, 2019 at 6:40 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    check the ground wires, and make sure your getting 12v to the lights pos. wire
    crf69[OP] likes this.
  3. Aug 4, 2019 at 7:40 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Have you seen the wiring that PIAA ships with their lights? It's better *quality* than most, but it's crap design. It *might* work in San Diego, but anywhere with salt & moisture, you're boned.
    OP, what's your wiring situation now... all added on, wired to the stock switch/relay, or a mix of both?
  4. Aug 4, 2019 at 7:42 AM
    BillsSR5
    bill
    2014 SR5
    actually I have PIAA foglights in my truck and had to use their supplied wiring harness my truck wasn't pre wired from factory, its been working at least 4 years now East coast weather :fingerscrossed:
  5. Aug 4, 2019 at 7:45 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Are you wanting lights that go into the factory bumper openings? I’ve got a pair of LED cube pods I’d sell.
  6. Aug 4, 2019 at 7:45 AM
    crf69
    Ohio
    ummm yeah
    what i did a decade ago was just cut the wires and solder the wires in, worked great but being in northern ohio i can now confirm the wiring is shot with corrosion, thats why im just looking to maybe bypass the whole stock setup
  7. Aug 4, 2019 at 7:46 AM
    BillsSR5
    bill
    2014 SR5
    put in the 4 sale section FYI
  8. Aug 4, 2019 at 7:47 AM
    BillsSR5
    bill
    2014 SR5
    are u getting voltage where it plugs into each light?
    crf69[QUOTED][OP] likes this.
  9. Aug 4, 2019 at 7:50 AM
    fb40dash5
    11 V6 AC 4x4
    That's impressive, I think mine made it 2 years or so... and that was the relay under the hood, I put proper sealed connectors out at the lamps.
    I picked up a real anal-retentiveness about sealing connections from working on plow trucks and pushing snow. Seemed like anything else was just a bandaid, and would 100% guaranteed fail in the worst conditions when you needed it most... nope, doesn't fail over the summer where you catch it going over stuff pre-season, it waits til 2am in a 10 degree blizzard!
    BillsSR5[QUOTED] likes this.
  10. Aug 4, 2019 at 7:54 AM
    BillsSR5
    bill
    2014 SR5
    I have the LED PIAA fog kit that goes in the OEM fog holes, didn't need to use a relay because of the low amperage of the LEDs the actual on/off switch acts as a relay. yes I really wrapped the splices good but didn't solder any. I used the cheesy supplied harness from the PIAA kit
  11. Aug 4, 2019 at 8:00 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  12. Aug 4, 2019 at 8:10 AM
    crf69
    Ohio
    ummm yeah
    nope, i also checked the fuse and the relay with multimeter, both outside the truck
