foglights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryantaco10, May 8, 2010.
  1. May 8, 2010 at 11:37 PM
    ryantaco10
    ryantaco10 [OP] Member
    ryan
    hanford ca
    2010 tacoma pre runner sr5
    none yet. hopefully a 3 inch pro comp suspension lift, exhaust, intake, rims and tires
    my fog lights come on only when i turn the headlights on. is there a way i can turn them on w/o havin to turn on the dam headlights all the time? its on a 2010 taco
  2. May 8, 2010 at 11:40 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
  3. May 8, 2010 at 11:50 PM
    1980 Well-Known Member
    The Dust Bowl
    Remember that in most states fog lights may only be used in conjunction with the low beam headlamps if you are on a regulated road.
  4. May 8, 2010 at 11:52 PM
    MOT
    Daniel
    Las Vegas
    True But Funk the police! haha!:D
  5. May 10, 2010 at 6:40 PM
    ryantaco10
    ryan
    hanford ca
    ok well theres 2 green wires when i pop off the cover. which one do i cut into? n yes funk the police.
  6. May 10, 2010 at 8:11 PM
    MOT
    Daniel
    Las Vegas
    Bro when you take of the pannel frist pull the pug out that has the green wire the smaller plug at the top then get the tap in and tap in the green wire to the wire you are using then drill a small hole in the box to run the wire over and pull the relay for the fog bend the side out and pul the wire in to it plug ever thing back in and your good to go very eazy! If you need pics pm me!
