Fogs Anytime=Dead Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bjasper, Feb 23, 2012.
  1. Feb 23, 2012 at 8:13 PM
    bjasper
    bjasper [OP] Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    Today I tried to do the Fog Lights Anytime, but I ran out of time and just left out the fuse and did not reattach the "green" wire. Then I noticed my tail lights might be out, but they weren't. So I put the fuse back in and reconnected the circuit and the fogs worked again. However, later today I ended up on the side of the road with a dead truck. The radio went out first then the speedometer went to 0. Eventually, it didn't start and the lights worked for only short periods of time.
    I think the alternator might be broken or the battery is not recharging. Could this be because of a problem with the fuse box?
    Has anything like this happened to anyone else?
  2. Feb 23, 2012 at 8:14 PM
    Aw9d
    Aw9d That one guy
    Az
    I just did this mod about 5 days ago and had no issues. Got any pic's of what you installed?
  3. Feb 23, 2012 at 8:22 PM
    himmie
    himmie Well-Known Member
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Visit the Build.
    I have never had issues with mine. Photo of what you did would be helpful.
  4. Feb 23, 2012 at 8:24 PM
    bjasper
    Brian
    Carmel, CA
    06 TRD PreRunner
    Its in the shop right now, but all I did was splice the green wire back together and it worked again.
  5. Feb 23, 2012 at 8:29 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    I didn't splice a green wire.
  6. Feb 23, 2012 at 8:30 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
  7. Feb 23, 2012 at 8:31 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    There is multiple ways to do the mod. Where'd you get the write-up to do it?
  8. Feb 23, 2012 at 8:58 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    don't know which write up you followed, but it should have only taken 15min tops.
  9. Feb 23, 2012 at 9:18 PM
    bjasper
    Brian
    Carmel, CA
    06 TRD PreRunner
    I used the write up I'm piercedtiger's cheap/free mod thread. I couldn't find any others that made sense to me.
  10. Feb 24, 2012 at 6:35 PM
    dYL0n
    Dyl0n
    New Orleans, LA
  11. Feb 24, 2012 at 7:20 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Don't cut the green wire. Tap "into" it. The wire has to be connected other wise it bypass the charging system and doesnt send a charge to your battery. I had the same problem. Just re-connect the green wire
  12. Feb 24, 2012 at 7:23 PM
    RedOctober
    RedOctober Taco lova
    Albany, NY
    08 Speedway Blue TRD Off Road
    Yeah the 2012's are different but I think the links posted should work. I would redo it and you should be all set.
  13. Feb 24, 2012 at 7:39 PM
    wrxRome
    Brandon
    You most likely burned a cell in your battery too. I had to change mine
  14. Feb 25, 2012 at 2:27 AM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    yeah, similar thing happened to me yesterday, but the truck didn't die......just lost the speedo, compass, outside temp, power windows, temp and fan (cabin), had the lights on for parking brake, traction control, and abs.......I looked back at the foglights anytime mod for 2nd gen 05-11 and someone had the same issue.
    all it was was a 10A fuse for ign2 that had blown....guessing that the fuse is linked to a relay to give power to all those things....it's fixed now.
    Good luck with yours OP
  15. Feb 25, 2012 at 6:10 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Like others said, don't cut the green wire, splice/tap into it. People really need to learn the difference between cut and splice before trying electrical mods.
  16. Feb 25, 2012 at 6:18 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Or dont do them if you don't know what you're doing.
  17. Feb 25, 2012 at 7:19 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah. A lot of these mods only work if you splice (tap) into a wire, and things break if you cut. While others actually require cutting a wire. Some mods require both, and doing the wrong order really f's things up.
