Fogs on Anytime :: Help
Discussion in 'Technical Chat' started by trdferguson, Oct 19, 2009.
  1. Oct 19, 2009 at 1:17 PM
    trdferguson
    trdferguson [OP] Active Member
    Yorktown, VA
    08 Tacoma DC/SB TRD Sport
  2. Oct 19, 2009 at 1:22 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    the pic works bro. I did it like 2 weeks ago on my 07. it's gotta be your spade connection or your T splice connection that aint working!
  3. Oct 19, 2009 at 1:26 PM
    trdferguson
    Yorktown, VA
    I bet it does work..
    I'll go back and check, at first I thought it was the splice, but nah.. thats in there good. I didn't check my spade connector, I figured that was just outta the question cause it looked solid, but I'll go check it again Thanks!
  4. Oct 19, 2009 at 5:09 PM
    trdferguson
    Yorktown, VA
    yup, i'm a big dummy =P didnt press hard enough on the connect. works like a champ now! thanks
  5. Oct 19, 2009 at 5:14 PM
    Slygrin
    Slygrin Well-Known Member
    Moses Lake, WA
    2010 Access cab V6 SR5 Timberland Mica
    De-badged, Foglights on anytime, Tailgate hose clamps, GPS semi-permanent mount, WeatherTech mats, Front mounted hitch, Blacked out front emblem, Color matched grille, Running boards, Bed mat, UWS low profile toolbox, Scanguage II, Prestige Alarm w/remote start, Snowsport snow plow
    When I did mine the quick splice I used cut the wire all the way through and caused an intermittent connection. I could wiggle the wires at the splice and get the lights would flicker. I removed the splice and soldered the connection. It's been working great since.
  6. Oct 19, 2009 at 5:57 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    awesome man. glad it worked. Its such an easy mod. can't really screw it up unless somethings a little loose.
  7. Oct 25, 2009 at 9:18 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Sine this is a help thread I figured I post my question here too. With this mod, is it the case that the fogs will run only when the ignition is on?
    So I can run my high beams and still have my fogs on?
    Or I could run my fogs with the head lamps off all together?
  8. Oct 25, 2009 at 9:37 PM
    Crom
    Nick
    San Diego, CA
    Millions
    I found the answer to my questions in another thread (ignition must be on). I also found out (FWIW) it's illegal to run the fogs with the high beams on. What's more is that according to somebody who knows that they are talking about, its actually bad for the driver's eyes to run the fogs AND the high beams at the same time. See this link for the article on fogs
