Fogs on while brights on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by codyjphoto, Jan 22, 2022.
  1. Jan 22, 2022 at 5:27 PM
    codyjphoto
    codyjphoto [OP] Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Relatively straight forward, I'm looking for any way to bypass the fogs cutting off while using brights.
    Thanks in advance!
  2. Jan 22, 2022 at 5:31 PM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
  3. Jan 22, 2022 at 5:32 PM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    Thanks! Sorry for the lack of search function
  4. Jan 22, 2022 at 5:49 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Why - so you can really blind oncoming drivers?
    There are a few threads on this topic here. A brief search will find them.
  5. Jan 22, 2022 at 5:50 PM
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    Just adding to the post count huh?
  6. Jan 22, 2022 at 6:32 PM
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    High beams shouldn't be on with oncoming traffic. If they are, having the fog lights won't be what's blinding.
    Tulsa Taco, RobertH, BRFab and 11 others like this.
  7. Jan 22, 2022 at 6:35 PM
    turkeycreek29010
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    musicisevil, BT17, JoeSchmo and 2 others like this.
  8. Jan 22, 2022 at 6:43 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I wish there was an easy mod for this. So many times I’ve wished to have all my lights on while off-roading and finding camping spots. I don’t ever use my high beams while driving on the road…ever really.
  9. Jan 22, 2022 at 8:28 PM
    Dubdaddy86
    Dubdaddy86 Well-Known Member
    I have the brite box on my truck. Super quick and easy install. I’ve been very pleased thus far for about a year now
  10. Jan 22, 2022 at 8:30 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Brights on and fogs is nice off road. But that’s where a light bar or pods come in to play. Leave the stock fogs alone and add aftermarket on a separate switch. So much easier that way too.
  11. Jan 22, 2022 at 8:31 PM
    Montana_Actual
    Montana_Actual ;)
    If your brights are on you are already "blinding other drivers".
    @OP, I guess as long as you can turn the fogs on by themselves without the brights then do what you want, but you should probably just consider a light bar instead.
    TDImark, Snotrocket, grogie and 2 others like this.
  12. Jan 22, 2022 at 8:53 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    I’ll have to take a look around my truck as when I cut the highs on the lows and fogs stay on. I only know this because I have leds in my lows, diode dynamic ambers in my fogs and can see the highs come on. I will double check and make sure I’m not drunk in thinking that. I did buy my truck used and it had mods done at the time of purchase.
  13. Jan 22, 2022 at 9:14 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    If using actual fogs, the two are opposed in function. Brights are intended for distance projection, adding more light up close will cause your pupils to constrict and reduce your ability to see to the full extent of the brights light output. On the other hand, brights are aimed high and create significant glare in the conditions that fog lights are needed in, and this glare effectively reduces your ability to use the light produced by the fogs. Fogs are designed for lighting up close to the vehicle and mounted low to reduce glare (the closer a light source is to your eye, the more you will see the light reflected back, try using a headlamp in the rain. Then hold it down by your waist).
    If you want more light, get pods that are designed for what you want. Specifically, if you want more light in conditions that brights are appropriate for, add something like Diode Dynamics SS3 Pro (or Max) SAE Aux driving light pods to your grill and wire them on a relay that is triggered by the brights coming on. If you want brighter fogs, get yellow Diode Dynamics SS3 Pro (or Max) SAE fogs.
    If you just want more light for off road, get a light set up that is designed for what you need and leave the road legal lights alone.
    Also, dim your dash lights as low as possible. This will help dilate your pupils and allow you to use the light you have more efficiently.
  14. Jan 23, 2022 at 5:30 AM
    CT Yankee
    CT
    Nope.
    Just expressing an opinion.
  15. Jan 23, 2022 at 5:33 AM
    CT Yankee
    CT
    Sorry, but at this point in my life I find that even low beams + fogs are often too much on an oncoming vehicle.
    And yes, I do know the tricks to avoid the effects of too much light coming at me.
  16. Jan 23, 2022 at 5:40 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    EXACTLY... I love all the shopping mall tacos who raced to judgment about why anyone would want to do this. Silly monkeys assume you want to just be an ahole and blind oncoming traffic... that my friends, is why you never ass ume..
    pmoore4321, VaToy, WCTRDTaco and 2 others like this.
  17. Jan 23, 2022 at 7:00 AM
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    You can bypass the fog lights turning off with use of a relay, but you will have to splice 2 wires. Not a big deal if you know what you're doing.
    I did on my truck and it's been working fine for 4 years now.
  18. Jan 23, 2022 at 9:00 AM
    wayne0
    wayne0 Well-Known Member
    This!
    Also, in many states it's not legal to have the brights and fogs on at the same time, which is why our trucks are set up the way they are. Do at your own (and on coming drivers) risk. If your state regulates it, don't expect to get a sticker.
  19. Jan 23, 2022 at 9:32 AM
    Quicksander17
    Quicksander17 Well-Known Member
    Austin
    2017 Tacoma TRD Off-Road 4x4 Quicksand
    METAL: RRW Rock Sliders - https://www.relationsracewheels.com/collections/rock-sliders Body Armor Low Profile Steel Winch Bumper Body Armor Rear Steel Bumper DiamondBack Heavy Duty Aluminum Tonneau Ridge Runner Bed Rack System DV8 Low Profile Aluminum Roof Rack TRD Aluminum Skid Plate CBI Gas Tank Skid Plate PERFORMANCE: K&N Cold Air Intake K&N Throttle Controller Front Camera Emblem Mount and Backup Cam Controller LED Headlight Bulbs Pop n Lock Power Tailgate Lock Rear LED Tailgate Strip Reverse Backup LED Bulbs Sport Wing Door Ding Guards https://www.sportwing.com/FE-TACDC-Toyota-Tacoma-Double-Cab-Painted-Body-Side-Molding
    Posting comments like: “Why? So you can blind oncoming drivers?” is ignorant, unhelpful and a waste of space on here for those of us who are smart enough to know why he’s asking a relevant, insightful question that anyone on Tacoma World who actually takes their trucks off-roading like they were built to do would love to know the answer to.
    People asking the question of, "How to Activate Fog Lights With High Beams On?" aren’t dumb enough to use bright lights when other cars are around, especially oncoming traffic.. That is why there are multiple product development companies that make electronics to enable this handy feature to maximize our truck's potential.
    He’s asking the question to see further ahead and in front of the truck and to the side all at the same time for safety either driving in the middle of nowhere with no one around or on backroads / country roads where hitting a deer crossing through cornfields is common or maybe he’s off-roading and doesn’t want to hit objects or maybe he’s searching for a perfect campsite after dusk..
    @codyjphoto You can purchase the Bright Box for $94.99 and use the code “TAKE15OFF” for 15% off making it $80.74 with free shipping here:
    The Brite Box for Toyota Tacoma
    Just ordered one because I have also been wanting to do this modification.
    THAT is what this helpful website is for @CT Yankee
    NOT your ignorant comments/opinions cluttering up this forum website for those of us on here to Help Get Shit Done.
  20. Jan 23, 2022 at 9:40 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Have you ever tried to use bright lights AND fog lights at the same time in FOG. You can't see shit. I've been in seriously heavy fog in the past and could see better with my lights off and just using the light from the parking lights + fog lights.
    But I understand what the OP is trying to do. There are better options. The factory fog lights are designed to help you see in fog. If you want additional light along with your bright lights adding additional driving lights is a better plan.
