fogs on with hi beam?
Discussion in 'Lighting' started by IndianTaco, Sep 6, 2010.
  1. Sep 6, 2010 at 3:57 PM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    im installing some aftermarket piaa driving lights and want them to turn on/off with the hi beams. i already did the fog light anytime mod with another set of light im running.
  2. Sep 6, 2010 at 4:10 PM
    jfisher
    jfisher Active Member
    when i put in my piaa lights i patched into my running light wire instead of going onto my high beam wire so i could have them on all the time. i think you should just be able to patch into the high beam wire with the power wire for the switch for them to come on only when the high beams are on
  3. Sep 7, 2010 at 7:27 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    It's easy. Purchase a relay and tap into the high beam wire for the trigger. When you switch to high beams, it will power the relay and pull power directly from the battery. The first time you wire up a relay it is a little confusing, but after that it's easy. You'll have one wire that will go to the battery, one to ground, one for a trigger, and one or two to your lights.
  4. Sep 7, 2010 at 7:37 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2, very simple. I'm running the exact set-up you're talking about. i've got a switch in the cab, but even with the switch 'on' the PIAA's won't turn on unless the hi beams are on. If you're pulling power directly off the batter, make sure you have an in-line fuse somewhere.
  5. Sep 7, 2010 at 7:48 AM
    IndianTaco
    what kinda relay?
  6. Sep 7, 2010 at 7:55 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    you do not need a relay. run the white/red hash switch wire to the high beam hot wire. this will allow the lights to only come on with the high beams when the piaa switch is on. use one of these to tap in:
  7. Sep 7, 2010 at 7:59 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have to disagree... you should always use a relay^^^^^
  8. Sep 7, 2010 at 8:05 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    :notsure: you have to get switch power from one source whether it be the parking lamp, low beam or high beam. I have done it this way on numerous vehicles without issue.
  9. Sep 7, 2010 at 8:06 AM
    Pugga
    Massachusetts
    F-150 Mod
    x2, for the couple bucks you'll spend on a relay, do it right.
    OP, you can pick up a relay at any autoparts store. They're pretty cheap.
  10. Sep 7, 2010 at 8:07 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    PIAA lights have a built in relay that comes with the harness. were not talking about a set of wally world fog lights. You get what you pay for, thats why PIAA's are in the neighborhood of $200 bucks instead of $39.99
  11. Sep 7, 2010 at 8:18 AM
    Pugga
    Massachusetts
    F-150 Mod
    Haha, I cut apart the PIAA wire harness. I didn't like their switch or connections. I soldered mine in. Looks like I could have saved myself some work though...
    And I want to know where you found PIAA's for $200!!
  12. Sep 7, 2010 at 8:58 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yea maybe not right at $200 even. Depends on what model PIAA's you get.
    My link below... PIAA 520 ATP series (pn:5296) for $244.12. They are one of the most popular part numbers.
  13. Sep 7, 2010 at 9:42 AM
    IndianTaco
    thanks guys for all the replys ill be doing this sometime after work
  14. Sep 8, 2010 at 3:47 PM
    IndianTaco
    ok guys what color is the hi beam wire on the back of the head light?
  15. Sep 9, 2010 at 8:21 AM
    Bama_TACO
    Winfield, AL
    I'm not sure but you can use a test light to figure it out.
