Fog's on with High's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18Taco, Feb 22, 2018.
  1. Mar 11, 2018 at 5:44 PM
    #81
    Grumpyhead
    Grumpyhead Member
    David
    Austin, TX
    2018 Tacoma SR5, 2WD Double cab
    Cosmic_3000,
    In your wiring set up would the fog lights turn on normally with the stalk switch? And I mean with the HBs off.
    Thanks,
    David
  2. Mar 11, 2018 at 6:23 PM
    #82
    rooney2oons
    rooney2oons Well-Known Member
    Dallas, Tx
    2016 TRD Off Road Silver
    Nothing yet....im a poor bastard.
    Deer. That alone is a good answer.
    NigelThornberry likes this.
  3. Mar 14, 2018 at 10:50 PM
    #83
    ferntr33
    ferntr33 Well-Known Member
    you would think if it would be illegal in any state to drive with fog lights on, it would be Kalifornia.
    I want to put some Baja Design Squadrons in fog location. Therefore using them as offroad lights using factory wiring harness. That way in the desert I can use high beams and my "Baja designs LED" foglights.
    ToyoDrew likes this.
  4. Mar 15, 2018 at 12:57 AM
    #84
    Onetime27
    Onetime27 Well-Known Member
    Joe
    Columbia Gorge, OR
    ‘20 OR DC
    275/70/16 AT3Ws
    In Oregon you cannot have your fogs on with oncoming traffic. They are essentially treated as high beams. That being said, most officers in my area don’t care, only a few troopers will stop for it.
    I will not stop a car for fog lights unless they are annoyingly bright and blinding. Or some jackass is running his light bar... drives me crazy.
    FrostHammer and ToyoDrew like this.
  5. Jul 3, 2018 at 9:17 PM
    #85
    bnh032
    bnh032 Active Member
    Brandon
    18' cement trd off road
    IIRC on the 5th gen 4runner you could just bend a pin on a relay in the box under the hood, and it would make the fogs run whenever you wanted... And now for the life of me I cant find any of the DIY
  6. Jul 3, 2018 at 9:21 PM
    #86
    bnh032
    Brandon
    The Fog lights them selves are from @CaliRaisedLed ? Have they been discontinued?
  7. Jul 3, 2018 at 11:51 PM
    #87
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    Yes they are, and no they haven't been discontinued. What makes you say that?
  8. Jul 4, 2018 at 1:37 AM
    #88
    Sasquatchian
    Sasquatchian Well-Known Member
    Most factory fog lights are pretty useless, however, when you over light the foreground with fog lights on in conjunction with your high beams, your pupils close down adjusting to the brighter foreground light, reducing the effectiveness of your high beams. . This is something we started noticing back in the late 1970's when we were putting Cibié low beams, pencil beams and 175 series fogs on our Datsun 510s. Back then we wired those 175's (and those are some of the best fogs available then or today. You can still get them from Stern, and anyone serious about lighting should know Daniel Stern.) separately with heavy gauge wire and relays so it was easy to have all the lights on at once. You immediately saw how much your distance vision was reduced with both fogs and high beams on at once.
    2016Tacoman likes this.
  9. Jul 4, 2018 at 6:11 AM
    #89
    bnh032
    Brandon
    I didn’t see them on the site under 2016+ tacoma. Only the square.
    I’ll look again
  10. Jul 4, 2018 at 8:47 AM
    #90
    Midknight
    Western Canada
    2018 TRD Off-Road
    I think you miss understood my initial post, and then I miss understood yours hahaha
    I was saying that Caliraised makes something similar to the photo I posted. The photo is from the Baja Designs fog setup. Caliraised lights are square as you noted.
    Both setups are great, just depends on how much money you want to spend on lighting.
  11. Jul 4, 2018 at 9:18 AM
    #91
    bnh032
    Brandon
    That’s 100% what happened. I thought they may have reproduced Bajas design.
    Midknight likes this.
  12. Dec 26, 2020 at 7:10 AM
    #92
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    Sorry to get back so late. Yes with the HB's off, the fog lights work normal, the stalk will turn them on/off. With HB's on, the fog lights are always on, it will override the stalk. So if you fog lights are switched off, turning HB's on will also turn on the fog lights.
  13. Dec 26, 2020 at 8:05 AM
    #93
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Only two years, no biggy.
    Ruggybuggy likes this.
  14. Dec 26, 2020 at 10:01 AM
    #94
    cosmic_3000
    '17 OR DCLB w/ JBL
    Better late than never!
  15. Dec 26, 2020 at 11:55 AM
    #95
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Most of the time I see these on F150s....half the LEDs are burnt out and they look like shit.
    Chew likes this.
