fogs/short/multimeter
Discussion in 'Lighting' started by rab89, Oct 5, 2009.
  1. Oct 5, 2009 at 6:01 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I have some fogs on my truck, they were wired to a switch, the switch kept blowing so I cut the wire under the hood and ran it into the DTRL fuse, I like the idea of it, but I'm not sure if the switch was blowing because of a short or what?
    I picked up a multimeter the other day and am still learning to use it, how do I check for a short with my multimeter?
    and lastly, I'm not using a relay, should I get one?
    thanks again TW!
  2. Oct 5, 2009 at 6:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes use a relay. If it was shorted, you should have a blown fuse. Or the switch was underrated for the lights. This would make it act like a fuse.
    A short means a direct path to ground (in this case). You would have your meter set to Ω. You need to find the side of the switch where the power would go to the lights when the switch is thrown. One lead will be on that and one goes to ground. If you get a small reading then there is a short.
  3. Oct 5, 2009 at 6:35 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I didnt have a fuse in the line so no blown fuse.
    if I take out the wire from the dtrl fuse slow, and connect the positive lead to the wire and the negative lead to my battery ground is that gona work? (very new with the meter)
  4. Oct 5, 2009 at 6:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    As long as the wire isn't the Batt +, yes that will work. And get a fuse in there.
  5. Oct 5, 2009 at 6:50 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    sounds good, I just pulled the truck into the garage, I'll let you know how it goes, and I have a fuse too so i'll set that up
  6. Oct 5, 2009 at 8:42 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Alright so I checked the wire with my multimeter, It was showing 0.5 ohms, which from what I read is good to go. so I put a fuse in, checked it again, and everything was good so it's all up and running now.
    thanks 98tacoma27!!!!!!!
  7. Oct 6, 2009 at 6:20 AM
    98tacoma27
    Ben
    Not Beech Creek
