Fogs stopped working..
Discussion in 'Technical Chat' started by MyToyTaco, Dec 17, 2009.
  1. Dec 17, 2009 at 9:22 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I noticed this last night leaving work. Keep in mind, I haven't done any mods related to the headlights or fog lights.
    My fog lights won't turn on. Either of them. Also, the green bulb on the dash that shows the fog lights are on; that bulb is always on, whether the switch is in the on or off position.
    Anybody have an idea what to check? I thought about the bulbs going bad, but I find it odd that they would both go out at the SAME time. I don't really want to buy bulbs and have that not be the problem.
  2. Dec 17, 2009 at 9:23 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    fuses?
  3. Dec 17, 2009 at 9:33 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1. Or maybe the relay?:notsure:
  4. Dec 17, 2009 at 9:37 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    fuse is in good shape...where would the relay be
  5. Dec 17, 2009 at 9:39 AM
    McJosh
    Josh
    Chandler
    the relay is the compartment under the hood isn't it?
  6. Dec 17, 2009 at 9:41 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    It sounds weird to me that the green fog dash light is always on with the button on or off?:cool:
  7. Dec 17, 2009 at 9:41 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    thats where the fuse is..
    so the fogs would have a relay and a fuse? im not that familiar with electrical, i would have thought there would be one or the other
  8. Dec 17, 2009 at 9:42 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    i know me too. I'm wondering if a critter got in there and chewed some wires up. I'll have to crawl under there and check..
  9. Dec 17, 2009 at 9:44 AM
    McJosh
    Josh
    Chandler
    the fuse is in the little compartment down and to the left of the steering wheel. pull it out and there should be fuses. There is a sticker on the back of the compartment that shows the layout.
  10. Dec 17, 2009 at 9:45 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I checked both places, the fog fuse is under the hood. Couldn't find one by the steering wheel.
  11. Dec 17, 2009 at 9:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    There are both a relay and fuse. Actually 2 fuses, one for th coil of the relay and one for the fogs. And the power to the fog relay coil has to pass through two other relays.
  12. Dec 17, 2009 at 9:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    The fog relay is not located there.
  13. Dec 17, 2009 at 9:49 AM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    the second fuse box should be behind your little change drawer thing to the left of the steering wheel..just pop that off and look behind it..should be able to see if its any fuse..or it could also be a wire issue as well like somebody said.
  14. Dec 17, 2009 at 9:58 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I don't see anything in the box by the steering wheel that resembles "fog".
    I located the relay under the hood (thanks Ben). But how the hell to i inspect it? I can't even figure out how to remove it.. lol
  15. Dec 17, 2009 at 10:10 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Most relays pull straight out. One way to test the relay is to find another relay in the fuse box with the same number on it and swap them. There is probably a better way to do it, hopefully someone more knowlegeable will chime in.
  16. Dec 17, 2009 at 10:11 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    It wouldn't pull out very easy, and I didn't want to break it. Does it just need a little upward force? It seemed like there was some trick to remove it that I was missing..
  17. Dec 17, 2009 at 10:26 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    To be honest, I've never pulled a relay in my Tacoma, but in every other vehicle that I've seen, the relay pulls straight out.
  18. Dec 17, 2009 at 11:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    I see you didn't check the bulbs because you didn't want to but new ones, but I think you should check them out regardless. It is actually common for them to both burn out at the same time.
  19. Dec 17, 2009 at 11:19 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I did glance at them thru the casing while checking the fuses, and the wire inside the bulb looked to be intact. Could this be deceiving? Maybe I'll get bulbs anyway and if it still doesn't work I can try to return them, or at least keep them as spares.
  20. Dec 17, 2009 at 11:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it can be deceiving.
