Folding down rear seat with ebay/Amazon dual 10" sub box...
Discussion in 'Audio & Video' started by CrazyDiamond, May 1, 2013.
  1. May 10, 2013 at 4:40 PM
    C Wills
    C Wills Well-Known Member
    Cearyx aka C Gutta
    Englewood,nj
    DCSB
    20% tint, extang trifecta tonneau cover.
    I think I'm gonna get the box that river dog has. I'm only gonna run one sub.
  2. May 13, 2013 at 12:05 AM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    If you do buy this box, or have bought it already, keep in mind that I had to remove one or more (I can't remember how many) of those tabs that stick out from the back wall. I think that plastic thing/tub behind the seat screws into those tabs. I'm sorry, but I can't remember if I removed them so there would be enough space, or if I just wanted a flat surface to apply Dynamat. Maybe someone else can chime in if they know for sure if you have to remove those tabs.
    If you haven't already bought the box, talk to Mr Marv. He would likely know for sure. I haven't done business with him, but everyone else on here says he's the best.
  3. May 13, 2013 at 7:26 AM
    C Wills
    Cearyx aka C Gutta
    Englewood,nj
    DCSB
    How did you Mount your amp/s?
  4. May 14, 2013 at 8:25 PM
    Riverdog
    Collin
    Portland, OR
    I wanted to keep a pretty low-key look to it all so I mounted the amp to the black plastic thing. I had to remove the shelf on the black plastic thing with a dremel and cut a few holes for wires. I was a little concerned with heat in the beginning, but I've checked it multiple times after running it a long time at high volumes and its never too hot to damage the plastic. If I could do it all over again, I would have mounted it an inch or two higher and ran all the wires through one hole rather than three. I'm not sure why I decided three was better :confused:
    The amp is a JL Audio XD300/1. I could have gotten a more powerful amp, but I liked the size of this one and its still plenty powerful.
    In this picture, you can see the outline of where the shelf used to be and the holes I made for the wires. All that red red cable is for a four-channel amp I have yet to buy. I ran the cables for it to save me time when I eventually buy the amp. :cool:
  5. May 15, 2013 at 4:52 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Whats that orange and green thing left of the amp?
  6. May 15, 2013 at 6:19 AM
    C Wills
    Cearyx aka C Gutta
    Englewood,nj
    DCSB
    That's a nice little setup you have. I like the fact that you still have a lot of room leftover for storage. I decided to go with the Amazon box because I want to mount the amp in the middle. I also like the option of adding another sub. Just incase one isn't enough. And if it is enough I could always open the other side and use it for storage. I seen a couple of guys on here do that.
  7. May 15, 2013 at 7:02 AM
    CrazyDiamond
    CrazyDiamond [OP] Active Member
    2011 4x4 TRD / DC / SB
    That is my plan as well. I test fitted my old 4-channel amp, and it was too tall and too long (old infinity amp) though.
    So, I picked up a 4-channel Alpine and a monoblock sub amp. These both will fit in the middle of the subs. It's going to be a tight fit, but they do set in there nicely.
    I Just need to fine time to actually install it, and then I'll post some pics. Life just keeps getting in the way...
  8. May 15, 2013 at 8:44 AM
    Riverdog
    Collin
    Portland, OR
    It's a distribution block. I don't really need it right now since I only have one amp, I just put it in now to save me time later when I get a second amp. The orange and green parts are the fuses themselves. They're very brightly colored for some reason. :rolleyes:
  9. May 15, 2013 at 8:47 AM
    Riverdog
    Collin
    Portland, OR
    Thanks! I like your plan of starting with one sub. I like having just one sub. Two would be cool and all, but one suits my needs just fine. Make sure to post up some pictures once you get it all installed to show it all off.
  10. May 15, 2013 at 8:53 AM
    Riverdog
    Collin
    Portland, OR
    Sounds like you'll have a great system. Sometimes just fining the time to install a system can be the hardest part. Mine took a lot longer than I anticipated. But then again, it was my first sub and amp install. Good luck with your install and be sure to post up some pics of the finished product!
  11. May 15, 2013 at 9:36 AM
    CrazyDiamond
    I hope mine turns out as clean as yours :D
  12. May 16, 2013 at 1:08 PM
    Riverdog
    Collin
    Portland, OR
    Thanks! I hope it does too.
  13. Jun 19, 2013 at 6:34 PM
    hogdoc
    hogdoc Member
    Greg
    Id Ho
    Just sink the sub so it fits flush with the front of the box, simple solutions are always the best!
  14. Jul 6, 2013 at 6:46 AM
    C Wills
    Cearyx aka C Gutta
    Englewood,nj
    DCSB
    I folded my rear seat down yesterday. I had my dog back there. No problems. I must admit I was a little nervous. All I need is for him to put his foot through my sub. But everything worked out good.
  15. Jul 6, 2013 at 4:46 PM
    #35
    Riverdog
    Collin
    Portland, OR
    Nice. Tell your pup to keep up the good work!
