Folding or roll up tonneau cover?
Discussion in '4th Gen. Tacomas (2024+)' started by cmillls45, Mar 16, 2025.
  1. Mar 16, 2025 at 9:43 PM
    JDTRD01
    JDTRD01 Member
    Illinois
    2005 DCSB TRD offroad
    Roll up Velcro usually doesn't last more than 2 or 3 years
  2. Mar 17, 2025 at 8:50 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I never considered the backflip mostly because it would cover up the back window. My dilemma was between the roll up and the Retrax Pro both with the T slot rails. Went with the retrax. Deciding factor was that I didn't want to risk the cover rolling loose and hitting the back window. I just didn't want to take a chance on it happening
    Iqudayo likes this.
  3. Mar 17, 2025 at 8:52 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I had an Access limited cover that lasted well past three years more like ten before I replaced the vinyl as the old one was toasted due to the Texas sun.
    Burns likes this.
  4. Apr 23, 2025 at 9:37 PM
    wfxt
    wfxt Well-Known Member
    The Empire State
    2025 Underground THLB (2021 MGM T4R Pro)
    Just went in on a TruXedo Pro X15 Soft Roll Up Tonneau, as I don’t like the folding kind, and, as I couldn’t justify the expense of the hard roll ups or the retractable ones, I bought what seems like a high-end soft rolling cover. I had a TruxSport for nearly 8 years with no problem and this should be better.
    RealTruck likes this.
  5. Apr 24, 2025 at 2:23 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    Folding!
    I've had both and the folding looks better, holds up longer, and is more secure.
    MagnoliaPhil likes this.
  6. Apr 24, 2025 at 3:26 AM
    Ooze
    Ooze Active Member
    2018 Tacoma Sport
    I liked my bakflip but it only lasted 5 or 6 years before it started falling apart. I've got it cobbled together with door hinges until I decide which covet to buy next. I'm leaning towards the DB switchback but don't like the fact that's it's not a true trifold. I do believe that it'll outlast all the other covers and I'm a beliver in pay once, cry once.
  7. Apr 24, 2025 at 6:49 AM
    22TCLB
    22TCLB Well-Known Member
    Tim
    2022 tacoma lb
    Can you post some pictures? Thinking about going with the Truxedo also.
  8. Apr 24, 2025 at 12:30 PM
    wfxt
    The Empire State
    I totally will when I get it installed, which is likely to be a couple of weeks at this rate.
    I’ll have to take off the ARB sport bar and side panels, so eventually I’ll put those up on the marketplace when ready.
  9. Apr 25, 2025 at 8:19 AM
    Lock24
    Lock24 Well-Known Member
    Western Washington
    Now: 2022 SR5 DCLB V6 4x4 (Was: '24 SR5 DCBL)
    Which is right depends on how you use your truck bed, how secure you want it to be, and if you want some portion of your back window blocked when needing to fold/roll the cover for tall items.
    I've had them all, and my favorite so far has been the Bak Revolver (I had the first gen version on a '17 Super Duty back when my kids were racing ATV Motocross). Needed a locking cover for security purposes (expensive gear in the bed!) and I don't like the folding covers when they are folded up almost hitting the back of the cab (and blocking the window somewhat). Need to haul a quad or go to the dump - easy: Just roll the thing up and clip it in place and it didn't block the view from the back window nor eat up hardly any of the bed space. The locking aluminum roll up was perfect for me back then.
    But dang they have got expensive! I just priced one for my 3G and they are ~$1500. Yikes; I don't really need the 'security' portion anymore like I did back then, so I may just go back to an old school roll up fabric cover that doesn't lock but hopefully does a decent job of keeping water out of the bed for trips to Costco, etc.
  10. Apr 25, 2025 at 3:49 PM
    MagnoliaPhil
    MagnoliaPhil Active Member
    Tri-Cities, WA
    2024 Tacoma Limited I-FORCE MAX, Celestial Silver
    No changes other than window tint & door vent visors
    My new 2024 Tacoma came with the OEM hard cover and I'm very satisfied with it. This is the first hard cover I've had, did not install covers on the beds of my previous pickups (Chevy and GMC) but had always thought about doing so. I like having the ability to keep things in the bed that are out of sight and reasonably secure, and it is very easy to open the cover for access. It also is reasonably water-tight - when I run this pickup through a car wash and then check to see if any water is in the bed, I only see a very small amount on the back corners, nothing that would get stuff wet in the bed.
    WhakoDog likes this.
  11. Apr 26, 2025 at 7:56 AM
    RealTruck
    RealTruck Well-Known Member Vendor
    There are some great shots of the RealTruck Truxedo Pro X15 Soft Roll Up Tonneau Cover installed on a Tacoma on our website. Feel free to PM me or email me at forums@realtruck.com if you have any specific questions about Truxedo covers. I can check stock, get you a pricing quote, and ensure that this is a perfect fit!
    trainsktg and 22TCLB[QUOTED] like this.
  12. Apr 26, 2025 at 8:26 AM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I work from my truck & carry tools in the bed so security is important. Had a cheap roll up velcro one, lasted less than 2 yrs.
    I've had several trifolds, some better than others. Best IMO was the leer with its very secure sliding latches. The 2023 has a Bakflip MX4, worst purchase ever. It's lower quality compared to the Leer & those hanging cable releases are a fucking joke. Even with a remote locking tailgate, I watched 2 guys pull up to the back of my locked truck, slip a coat hanger between the cover & tailgate, hook that cable & open it. I was yelling & moving as fast as I could (disabled) but they cleaned out my bed into their truck bed in a minute. If you look at a Leer, there's no cable release hanging down to snag. It's happened to me twice- once at Lowes & another time at Home Depot. Now I find myself moving some tools to the back seat if I park anywhere.
  13. Apr 30, 2025 at 6:04 AM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    We sell pretty much all of them... BAK, Leer, Undercover, Lomax, etc.
    As far as hard folding covers go our best longtime quality results have been with Lomax by far. We have sold a ton of them right here for Tacoma's alone and the results have been great.
    Leer makes a great cover. Only issue we have had is if you need their customer service for something they are hard to reach and slow.
    Hard rolling covers (Revolvers, Sentry, etc) are very versatile. Issue we have had has been long term they delaminate and fall apart. So if you don't keep trucks beyond a couple years its likely not an issue but long term truck owners will likely end up replacing them.
    We do offer some great discounts on everything we sell for forum members so if we can offer assistance with choosing and/or pricing let us know!
    cmillls45[OP] and gpb like this.
  14. May 2, 2025 at 8:08 AM
    WalfART1
    WalfART1 Well-Known Member
    2nd2forth
    simulated body damage
    Thats where i was at on the X4S. Hot vegas sun caused the metal interlocking parts to seperate on my 3rd gen in about 2 years, Co-workers glue let go as well on his chevy. Buddies f250 just keeps losing his plastic corners ( he beats the ever loving crap out of that truck and cover).
    But i ended up going with the relvolver on my 4th gen anyway.... warranty thing was annoying, they sent new ones, but not sure how a 2nd warranty claim will go. I hate the covers that roll up in the boxes eating up bed space and i hate the trifold ones. the relvolver is the best option IMO. maybe just not executed the best and needs some polishing
  15. May 2, 2025 at 8:14 AM
    #35
    truckalter
    Luke
    Waynesville, NC
    Its likely they are unable to find an adhesive that will hold up to the heat generated by a black cover over aluminum. I sell them every week to people that I inform its won't last but if you don't keep trucks long term its a very versatile cover while it lasts.
  16. May 5, 2025 at 7:56 PM
    #36
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Any thoughts on oem trifold cover vs bakflip? They seem very similar. Anyone have issues with either cover folded up against the cab, and then carrying items in the back pressed against it (like a couch with straps putting pressure on the cover?)
  17. May 6, 2025 at 3:07 AM
    #37
    Ooze
    Ooze Active Member
    2018 Tacoma Sport
    I've never hauled anything in my bed that was big enough to put pressure on the folded cover as it leans against the cab. I've got a 6 x 12 trailer that I use for large items. My only complaint with my bakflip is it started falling apart after 5 or 6 years of well cared for usage.
  18. May 6, 2025 at 5:58 AM
    #38
    truckalter
    Luke
    Waynesville, NC
    I can tell you the covers aren't designed to have pressure pushing them into the back of the cab. The rubber that holds them away from the cab is pretty small and I would have concerns that you might end up with paint rub or damage to the cover.
  19. May 8, 2025 at 7:29 PM
    #39
    pstpierre986
    pstpierre986 New Member
    Paul
    Any advice on the bakflip tonneau cover on a 2025 with the 6' bed? Does it block the digital rearview mirror camera when folded up against the cab?
  20. May 9, 2025 at 6:57 AM
    #40
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    After tons of research I’m picking up the diamondback SE cover. Seems like the best in terms of durability, looks, versatility, and price.
