Folding table saw stands
Discussion in 'Garage / Workshop' started by teamfast, May 3, 2012.
  1. May 3, 2012 at 5:10 PM
    teamfast
    teamfast [OP] Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Need a stand for my Ryobi BT3000. (Awesome saw if you need one), and nned a stand that i can fold up and get out of the way when not in use. Never seen this dewalt one before anyone else? At 220 bucks its pricey but I have the identical miter saw stand i paid 99 bucks for used (it was brand new).
    http://www.blackrocktools.com/dewalt-rolling-table-saw-stand-dw7440rs.html
    Also considering a very basic stand as well the Bosch
    http://www.google.ca/imgres?q=foldi...54&start=42&ndsp=15&ved=1t:429,r:7,s:42,i:183
  2. May 4, 2012 at 8:29 AM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    don't really have much experience in this vein, ..but the dewalt stand you posted looks pretty nice, ...and if it's just 33 lbs, i could see rigging a way to hang it on the garage wall..
  3. May 4, 2012 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its not hard to make them yourself. You can make them out of wood, and save some cash. That way, if you ever cut thru too far, and hit the stand with a drill bit, or saw blade, no damage is done.
  4. May 4, 2012 at 8:43 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I made a wood frame that I clamp in a Black & Decker Workmate, set my miter saw on it and get to cutting. :D works for me. That Dewalt stand does look nice.
  5. May 4, 2012 at 1:10 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    I bought the Bosch used for $45. He got it with the saw and never used it. Score! So I set it up and it has two height positions which is awesome. The stand will need a plywood insert to fit my saw but it will sit inside of the frame as per design. Very happy I found this so cheap. And it folds flat(about 3.5" I estimate) and only weighs about 22lbs (estimate).
  6. May 4, 2012 at 1:22 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have a Dewalt stand for my Dewalt miter saw, That thing is solid! I love it.
  7. May 5, 2012 at 5:10 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    The basic folding one or the one in the first post with wheels and everything?
  8. May 5, 2012 at 7:23 AM
    macgyver
    Brad
    Canton, GA
    Just the basic folding one.
  9. May 5, 2012 at 9:15 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    He's talking about the miter saw stand , not the tablesaw stand
  10. May 5, 2012 at 9:45 AM
    Ghoster
    Ghoster Well-Known Member
    Baltimore
    2012 PreRunner DCSB
    I have the Ridgid MS-UV. It is an absolute beast. It costs more than any that you have listed, but the build quality exceeds any of the ones you are looking at.
    I have attachment brackets for my miter saw and my table saw, takes 10 seconds to switch them out. Once its folded up you can drag this thing anywhere. I love it.
    Now the down side, it is HEAVY. You won't be hanging this thing on any walls. In fact, with my miter saw on it, it takes 2 people to lift. If you are looking for a stand that you will FREQUENTLY be folding up and putting away and pulling it back out, spend the $$$$ for a quality stand now. No regrets with mine, its awesome.
    On a side note, they don't sell the one I have anymore, its been replaced by a newer model.
  11. May 5, 2012 at 9:51 AM
    OZ-T
    Peter North
    British Columbia
    I'll take my plywood mitre saw table and a couple of folding aluminum sawhorses over these fancy stands any day
  12. May 5, 2012 at 10:26 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    I often use my Taco tailgate. Works pretty well, but no outfeed support.
  13. May 5, 2012 at 10:28 AM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    This is what I was going to say. If your a woodworker, you should be able to build one ;)
  14. May 5, 2012 at 10:42 AM
    OZ-T
    Peter North
    British Columbia
    I would never build a folding tablesaw stand out of wood .
    Not when you can buy a metal one so cheap .
    A mitre saw stand on the other hand , always build my own . I tried to like the DeWalt folding stand , I don't , it sits in the corner of my shop .
    I like being able to use the flat , 8' long surface of a plywood top to support the stock being cut off , as well as a clamping / working area for planing or sanding the trims I'm installing , I also have small cubbies under the table I keep my little hand tools , sandpaper etc in
  15. May 5, 2012 at 10:46 AM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    Build a couple of decent sawhorses. (make sure they are the kind that can "nest" one inside the other for storage) Make a mount for the miter saw and set it on top. A couple of carriage bolts, washers and wing nuts will hold the mount to the sawhorses and allow quick disassembly. If you spend more than $50 on this set up you're doing something wrong. Or... Go to your local vocational high school and ask if they can build you something. Pay for the lumber (maybe) and buy the kids a couple of pizzas.
  16. May 5, 2012 at 5:26 PM
    macgyver
    Brad
    Canton, GA
    I believe it will work for a table saw too though.
  17. May 5, 2012 at 5:34 PM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    This works if you are doing all your work in your own shop. I have dragged my saw on its folding table to many many places. My parents house, my sisters house, a few neighbors, and even a house being built by Habitat for Humanity. It just depends on how portable you want it to be.
  18. May 5, 2012 at 5:46 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    I love the dewalt mitre saw stand, have a basch mitre saw on it. Dont think i would try and build either though since the huge outfeed suports on the miter would be hard to replicate.
    I had a table saw cabinet I made out of 3/4 ply. It was nice but too heavy, great for shop, not for travel/space savings.
  19. May 5, 2012 at 6:23 PM
    OZ-T
    Peter North
    British Columbia
    Nope , my saw moves all over the place , it takes the same amount of time to break down my set up as it does the DeWalt folding stand
  20. May 5, 2012 at 7:22 PM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    Mine breaks down in 10 seconds or less, not including rolling up the cord, and rolls away in one trip. It sets up in the same amount of time. My stand is the Ridgid, not the DeWalt.
