Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 26, 2018 at 6:59 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    Will have to ask the wife :rofl:.
    But it is tortellini, heavy cream, peas, asparagus, bacon, onion, garlic, salt, and pepper. Really tasty!
  2. May 26, 2018 at 7:12 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    That's a good looking spread right there!
    grdgz97 and bvbull200[QUOTED] like this.
  3. May 26, 2018 at 7:36 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    :annoyed:
  4. May 26, 2018 at 9:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Scottalot starter pack...
  5. May 26, 2018 at 9:48 PM
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
  6. May 26, 2018 at 10:05 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    To be honest, I've never heard her say it before. It kind of took me by surprise.
    Bigdaddy4760 and scottalot like this.
  7. May 27, 2018 at 7:36 AM
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    With my second batch of Bresaola in the 15th day of the 21 day curing process I though it time to start a new project. So yesterday at BJ's Wholesale club I picked up a 9+ lb pork loin for right around $16.00
    Lonzino
    5-27-18
    Step 1
    . Pork loin unpacked toweled dried, cut in half and trimmed of fat cap and loose pieces. Meat also weighed to calculate spice/cure amounts.
    I ended up with pieces weighing:
    1758g
    1524g
    905g of trimmings
    Step 2. Gather spices and cure.
    Critical items are Cure #2, salt and sugar. All the other spices I base on my Bresaola and can be adjusted or omitted per your liking.
    Cure #2 - 0.25%
    Kosher salt - 3.00%
    Brown sugar - 0.05%
    Black pepper corns
    Granulated garlic
    Ground thyme
    Juniper berries
    Dried rosemary
    Fennel seed
    Whole clove
    Crushed red pepper
    I also toasted the pepper corns, fennel and juniper berries prior to grinding in the Ninja bullet. Then I mixed in the rest of the spices and cure related to the individual cut of mean and gave them a quick spin in the Ninja to blend thoroughly.
    Step 3. After blending the spices I put them into a cup with the weigh of the corresponding meat on it to keep from getting things mixed up. Cut a vac bag to length label with what you are making date and weight.
    Before spicing the meat I like to put a payer of parchment paper on the counter prior to for easier cleanup. The parchment paper will want to roll up on you so to keep this from happening sprinkle a little water on the counter and it paper will stick to it and lay flat. I also like to keep a dough knife handy to scrape up all the spice/cure that doesn't stick so I can collect it and put it in the vac bag with the meat for the curing process.
    Step 4. Rub the meat with spice/cure mixture all over. Collect and spice/cure mix that doesn stick and put it i the vac bag.
    Step 5. Vac out about 80% of the air and seal the bag. You want a little air space in the bag so you can swish the cure around in the coming weeks. Put in a overflow pan (bus pans work great for this and curing bacons plus they are inexpensive and food safe) in case a bag leaks and into a 38 to 42 degree fridge for at least 2 weeks flipping every 1 to 3 days.
    Note you can also put a weighted cookie sheet or something flat on top of the vac packed meat to press it flatter if you desire. Something in the 5 to 10lb range will work.
    See you in a couple weeks
  8. May 27, 2018 at 7:49 AM
    wilcam47
    Will
    Bourbon state
    s
    so not air cured?
  9. May 27, 2018 at 7:54 AM
    PerazziMx14
    Technically nothing is air cured. 1st step in the process is to cure the meat with cure, salt and sugar (spices are only there for flavor). After the meat is cured then it is air dried (under controlled conditions) until it loses 30 to 40% of its moisture. Lowering moisture content makes it so bacteria have a harder time establishing and growing and also you are intensifying the flavors through enzymatic breakdown an spices.
    scottalot, Bigdaddy4760 and wilcam47 like this.
  10. May 27, 2018 at 7:56 AM
    wilcam47
    Will
    Bourbon state
    so not air dried or is that a next step thing ;)
  11. May 27, 2018 at 8:54 AM
    krap22
    krap22 Well-Known Member
    Biscuits on the grill. Simply amazing and doesn't heat up the house on a really hot day.
  12. May 27, 2018 at 9:27 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
  13. May 27, 2018 at 9:29 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Ah I see @scottalot is picking up the rest of his Charcoal order
    Kanyon71, Jeppa63, grdgz97 and 3 others like this.
  14. May 27, 2018 at 9:30 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  15. May 27, 2018 at 9:45 AM
    PerazziMx14
    Air drying is one of the next steps.
    1. Cure.
    2. Rinse
    3. Inoculate with molds
    4. Let mold establish 24 to 48 hours
    5. Hang in curing chamber to allow controlled air dry
    Step 1 is a 2 to 3 week process depending on the meat thickness
    Steps 2 thru 4 occur within about 2-1/2 days
    Step 5 anywhere between 4 to 12 weeks depending on how your curing chambers is set up and the thickness of the meat.
    wilcam47[QUOTED] likes this.
  16. May 27, 2018 at 10:55 AM
    Lost In The Woods
    Eric
    Buckley, WA
    I was wondering if anyone has been using a Oklahoma Joe smoker and how they like it. My current smoker was really cheap and is going down hill fast. Originally I was looking at something a little nicer than Oklahoma Joe, but I spent my smoker money on suspension.... and tiers.... and sliders. So now I need to think a lot cheaper for a new smoker.:anonymous:
    DubfromGA, inwood customs and WBF610 like this.
  17. May 27, 2018 at 10:56 AM
    Winker
    Winker Well-Known Member
    Paul
    Kentucky
    2019 Subaru WRX
  18. May 27, 2018 at 11:33 AM
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Angus beef short ribs going on the smoker early tomorrow. Never tried them before!
  19. May 27, 2018 at 11:51 AM
    EPBlueTaco
    EPBlueTaco Well-Known Member
    Ted
    El Paso
    07 DCLB SR5
    None yet
    I use the MES myself. Works great so far
  20. May 27, 2018 at 3:10 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    I have some for tomorrow, too! Mine were actually the scrap from prepping tomahawks, so they're boneless, but the same meat. It's gonna be tasty. Yours are proper short rib; you're going to love them!
