Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. May 28, 2018 at 8:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I want to live at your house for like a week.
    Yemison, wilcam47, bvbull200 and 2 others like this.
  2. May 28, 2018 at 9:16 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. May 28, 2018 at 9:19 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    What are you leaning towards? I might go ahead and get one while I'm redoing my drum. I think some of those offer wireless monitoring, too, right? If so, now would be the time for me to get one instead of just getting the Thermoworks Smoke. Need to think on this for a bit.
  4. May 28, 2018 at 9:20 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I was going to ask if it was the dressing or crumbles, after further review I believe it is the crumbles. OK I HAVE to do this. I like all of the above. Thanks for the heads up!
    You can teach an old dog new tricks and I'm still learning. I have a feeling this is going to be one of those things that might make me change how I do wings.
    Those Costco skirt steaks are pretty darn good. No surprise there. Shower. Sleep. Worth it. Thank you Dr. Atkins. Splurged on the carmalized onions cooked in bacon grease tonight. Worth it.
    medic2230, Kanyon71, CurtB and 7 others like this.
  5. May 28, 2018 at 9:25 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Was really considering getting some Grill Grates, but damn those are pricey. I really only need them for the visual aspect of the steak cookoff we have coming up. Personally, I want that sear to hit as much surface as possible, but the judges want to see them. Not sure I can bring myself to spend $100 on that. Any other advantages over the standard grates? If I can justify them otherwise, I might be back in on them.
  6. May 28, 2018 at 9:31 PM
    wilcam47
    Will
    Bourbon state
    2 different gallons but you works great.
    https://www.homedepot.com/p/BEHR-Premium-1-gal-Wood-Stain-and-Finish-Stripper-06401N/202263937
    Must apply between 40-90˚ F (4.5-32˚ C). Pour BEHR PREMIUM NO. 64 Wood Stain & Finish Stripper directly onto surface and apply liberally using a nylon/poly brush or roller. Natural bristle brushes or lambs wool applicators are not recommended. Due to product thickness, DO NOT use pump, paint or other sprayers. Product will clog tip, resulting in leaking and dripping. Always keep surface wet by misting with water and re-apply NO. 64 if drying occurs. Finish will begin to lift from the surface. Repeat process as needed to keep the surface wet during the removal period. Most deteriorated finishes will start to lift after about 5-45 minutes. The coating should easily rinse off when ready. When the finish starts to lift, scrub the surface using a stiff bristle broom or brush. Rinse thoroughly with water from garden hose using nozzle at normal pressure, or use a pressure washer at a low setting (500-1200 PSI).
    DO NOT USE HIGH PRESSURE as this may harm the wood. If some of the old finish remains on the surface, repeat application procedure or spot sand as needed. Follow up with a product such as BEHR PREMIUM® NO. 63 All-In-One Wood Cleaner to remove stains, rejuvenate natural wood color and to neutralize the stripping action.
    scottalot and DubfromGA[QUOTED] like this.
  7. May 28, 2018 at 9:37 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    I have the smoke and the wireless gateway when it went on sale. Still haven't set up the gateway for the Smoke the remote handles every thing I need. Hell because I am so paranoid and don't like to leave it more than a few feet don't even need the gateway. But have it if I decide to use it.
    The Cyber Q or now guess it is the cloud offers remote monitoring and that is what I use most of the time in the WSM. 3 probes are nice, surprising how much difference 3 pieces of meat can vary in temps on the same cook. And you can graph and chart, it is much better in the new Cloud than the Q. But I figure you know how to use Excel now that you have finished your MBA:rofl:
    That fan controller is spot on..
    I have both and like both. The Cyber Q pit probe controls the speed of the pit fan. And has a little bit of programming logic to it. Enough to be effective.
    The Smoke is more of just a monitor. But they both have a place in my cooking.
    TW saying but true. Why not both?
    DubfromGA, RickS, truchador and 2 others like this.
  8. May 28, 2018 at 9:42 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    CyberQ has 3 probes total or 3 meat probes (not that I can't look this up myself)? I was looking heavily in to the ATCs a few years back, but now can't remember what all I learned. I thought I remembered one that had 4 meat probes and 1 pit? I can't remember who made it. I'd rather have a bunch of unused probe slots most of the time then not have enough even one time.
    Your setup is really solid and what I'd be looking to do in terms of weather protection and cleanliness of install. Ideally I'd have 4 meat probes, automatic temp controlling, wireless monitoring, and no WiFi requirement (so I can monitor wirelessly while at competitions). Might be asking a bit much, though.
    DubfromGA likes this.
  9. May 28, 2018 at 9:49 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Flareup. Marinated chicken. Bacon wrapped anything. Even heat distribution.
    I don't normally use them to sear steak, prefer direct flame. Last fall I was grouse hunting out of a cabin that I rented and knew had an 18" silver kettle. Took my jumbo Joe and grill grates with me because the Silver was of unknown quality and had been sitting for awhile. A friend from Texas and another from Ontario happened to be in the area and I of course volunteered to cook steaks. Prime. After burning a chimney on the silver split the grill grates so could do steaks for all 4 of us. There was another friend there from Silver Bay, Mn. also.
    I see no downside to the grill grates, but have used them in a positive manner a lot of times.
    DubfromGA, CurtB, RickS and 2 others like this.
  10. May 28, 2018 at 9:50 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Good deal. I appreciate the insight.
    I think I really just need that little panel on your Jumbo Joe. Can fit two steaks on there :laugh:.
    Cold Iron[QUOTED] likes this.
  11. May 28, 2018 at 9:52 PM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    3 meat probes and 1 pit probe. That's right you comp guys need to do 4 meats. See that is why you need both :D
    bvbull200[QUOTED] likes this.
  12. May 28, 2018 at 9:55 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    We use four different smokers for each of the meats. Four meats, four different temps, four different wood types. At least when all you have is UDS to compete on, you get to claim that little bit of silver lining :laugh:.
    I'd want it for cooking for parties/events. Four briskets in one drum would be nice to monitor individually. Or if I do a couple pork butts with a couple of briskets. Three is probably good, though. The biggest chunk just wouldn't get a probe as it is highly likely to be lagging behind the smallest one anyways.
  13. May 28, 2018 at 11:51 PM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Can be flipped over and the flat surface used to cook, too.
    Cold Iron likes this.
  14. May 29, 2018 at 2:13 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Thermal mass ftmfw
  15. May 29, 2018 at 2:25 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    That's what I did. Bought the setup for a 18 weber that I use on my 26. Works great and easily removed after the sear. They fit right into the weber charcoal starter.
  16. May 29, 2018 at 5:38 AM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    Yep. We eat a lot of berries in this house.
    Cold Iron and scottalot like this.
  17. May 29, 2018 at 6:55 AM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    Your correct, it does fit 2 steaks just about perfectly. And if the judges want sear marks it will give them to you.
    But I'm like you and prefer direct flame. It is why I let my cast iron grates go. IMO the more direct flame the better. Sometimes don't even use any grate at all. Especially if I am smoking something I'll throw a steak on the smoker then reverse sear it. About the only time I really do a reverse sear.
  18. May 29, 2018 at 7:01 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    One of these too!
    https://www.amazon.com/Lodge-LPP3-S...=1527602430&sr=1-6&keywords=lodge+bacon+press
  19. May 29, 2018 at 7:39 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Should use a color scheme from your logo and paint the logo on it also.
  20. May 29, 2018 at 7:50 AM
    Kanyon71
    MI
    Didn't get any pictures of the food from the camping trip this weekend (swore off tech for the weekend). We had brisket, pulled pork, dirty beans, breakfast burritos, cheese potatoes, bacon/cheddar burgers (about 3am after drinking all day/night lol) LOTS of alcohol. Was a great long weekend.
    Cold Iron and Bigdaddy4760 like this.
