Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jun 24, 2018 at 12:58 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I threw on a rack of St. Louis ribs for supper tonight and a couple pounds of thick cut bacon. I’m getting ripe backyard maters in. Thank the Lord is BLT season!!! That’s what the bacon will be used for.
    CurtB, Cold Iron, DubfromGA and 3 others like this.
  2. Jun 24, 2018 at 1:00 PM
    t4daddy
    North Alabama
    I prefer the flappers over drumettes too.
    DubfromGA[QUOTED] likes this.
  3. Jun 24, 2018 at 1:01 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    The weather got nice just in time for me to smoke all the meat for the wedding. Four butts today, four more tomorrow and then I'll weigh our haul and smoke one once we get to the venue wedding day if needed. These guys have another hour before I wrap with foil and get them to the proper temp.
    rob1208, oscolivar1, TK-422 and 6 others like this.
  4. Jun 24, 2018 at 1:42 PM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Looking great.
    BLT's are awesome !!!!
    I use a little bit of Duke's Mayo on mine.
    Son came home and asked what was up for eats. Told him there was a hunk of corned beef cooking for later.....he was hoping for something a bit more "right now", lol.
    These bad boys were in the fridge and went into the pan with the corned beef for a while.
    Son's kicker brats came out of boil broil pan and over the coals to finish off.
    Told him I was breaking out the heavy artillery on the sides. Seems that BiLo now has 72 different mustards......this one seemed fitting.
    He wanted one with the mustard & cheese....and one with the mustard & these pickled Vidalias. I gotta get more of these killer enhancers.
    He killed those two and then knocked down a third with the mustard & onions saying he'd be interested in Reuben or two when he got home later.....little joker puts away the grub and is lean and mean. Gotta love that metabolism.
  5. Jun 24, 2018 at 1:51 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Nice grill! Is that a Pitt's & Spitts Maverick 1250??
    Oh, and good looking grub! :thumbsup:
  6. Jun 24, 2018 at 1:51 PM
    t4daddy
    North Alabama
    Hey smoked bacon, get in my belly!!!!
  7. Jun 24, 2018 at 2:00 PM
    DubfromGA
    Greg
    2017 Black SR5 4WD
    That looks like a tasty payload !!!!
    t4daddy[QUOTED] likes this.
  8. Jun 24, 2018 at 2:02 PM
    DubfromGA
    Greg
    2017 Black SR5 4WD
    I'll bet those were devoured quickly.
    Looks delicious !!!!!
  9. Jun 24, 2018 at 2:55 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Yessir! P&S 1250. So worth it. and thank you :thumbsup:
    Still have a few left over. But not for long :D
  10. Jun 24, 2018 at 4:45 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Got two 2ish lb prime tri tips at costco today for $35, been wanting to try my hand at and tri tip figured this was the time! I also wanna ask the guru's for some input...
    I have a 18" Weber kettle I'm pretty comfortable with, was thinking of rubbing with SPG then snake the charcoal with some mesquite and let it go till it hits about 125°. Does this sound like a solid plan?
    Helps to have a friend in the meat dept!
    oscolivar1, TK-422, Cold Iron and 3 others like this.
  11. Jun 24, 2018 at 5:03 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Sounds good! Really, so long as you don't kill the tri tip to medium well to well done you should be ok. Remember mesquite is a stronger flavor, I usually use less if I'm using for smoking. Pecan is awesome, and "typically" oak is used. But any wood makes it tasty!
    I heart tri tip! Make sure you let it rest after you pull it off, maybe 10-15 min. Slice against the grain!!:cheers:
    nDub, itzyoboipaul, DubfromGA and 3 others like this.
  12. Jun 24, 2018 at 5:07 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Nice. I would add onion powder and paprika into that rub. Go heavy, it’ll make a nice tasty crust just at the edges, the salt won’t soak in much if you rub (pat, actually) about a half hour before putting on grill (allow the meat 30 mins out of fridge), so don’t worry about it being too much unless medical reasons. I wouldn’t use mesquite, too strong, I’d use oak or pecan or, if you want some strong, hickory. I take mine to 115, lower the grill to bottom section of WSM right above coals, and sear those beyotches over heavy flame a couple minutes on each side until IT of 125. Remove, let rest under foil for ten minutes, slice properly (grain runs in two directions), enjoy.
  13. Jun 24, 2018 at 5:07 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I'm gonna switch it to pecan, never used that either so now is a good time it sounds like!
  14. Jun 24, 2018 at 5:09 PM
    horstuff
    horstuff Re-member
    PNW
    Pecan is all I ever do with TT, oak hard to find in Seattle area.
  15. Jun 24, 2018 at 5:36 PM
    DubfromGA
    Greg
    2017 Black SR5 4WD
    Corned beef brisket turned out well.
    As did the homemade sauce.
  16. Jun 24, 2018 at 5:40 PM
    Misplaced Nebraskan
    Zach
    Austin
    :hungry: yes please!
  17. Jun 24, 2018 at 5:42 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Wife wanted fall off the bone ribs, that’s what she got!! Could barely cut them without falling apart. I used a little homemade rub, some pitfaced, then a little added brown sugar. Panned and foiled with more of the rub and sugar, and apple juice. Used the pan juice to thin down some commercial sauce, and glazed them. Wife said, whatever you did, do it again. They got a little dark after glazing, but the flavor was good. Used apple and hickory wood, I may stick with that combo in the future.
    wilcam47, nDub, oscolivar1 and 11 others like this.
  18. Jun 24, 2018 at 5:48 PM
    Misplaced Nebraskan
    Zach
    Austin
  19. Jun 24, 2018 at 6:03 PM
    DubfromGA
    Greg
    2017 Black SR5 4WD
    Here you go........
  20. Jun 24, 2018 at 6:04 PM
    Misplaced Nebraskan
    Zach
    Austin
