Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Sep 28, 2018 at 7:47 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I would recommend against it. It’ll be an uphill battle to get it to work properly. You’ll end up having a bad time and it’ll sour your experience. A good smoker is pretty easy to use.
    IMO get a weber kettle and use it as a smoker. You can pick up a 18” fairly cheep. Even cheaper on Craigslist; if you end up not liking it you’ll have a nice charcoal bbq either way.
    Cold Iron likes this.
  2. Sep 28, 2018 at 7:51 PM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    I learned to smoke fish out of one here in Fl where it's hot outside most of year. Sailfish and Spanish mackerel within a hour or so
    Cold Iron and nDub[QUOTED] like this.
  3. Sep 28, 2018 at 7:54 PM
    nDub
    Lead Free Gasoline
    Right on. As long as you know what you get.
    My father bought a cheapo Walmart smoker and could not get the thing to cook (hold temp) properly and threw the whole thing in the trash and swore it off.
    I started on a WSM and no problems!
    Cold Iron and Bigdaddy4760 like this.
  4. Sep 28, 2018 at 8:00 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    I'm badly wanting to apply Sailfish technique to the false tuna " Bonita" by soaking the body in saltwater with brown sugar and ice overnight, then cutting into steaks and smoking
  5. Sep 28, 2018 at 8:10 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    I'm trying to recall what chip we used it wasn't hickory I look for it last time at Wally World but all they had was hickory
    WBF610 and Bigdaddy4760 like this.
  6. Sep 29, 2018 at 3:44 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Alder?
  7. Sep 29, 2018 at 6:01 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    Is it darker than hickory?
    Bigdaddy4760 likes this.
  8. Sep 29, 2018 at 6:24 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    Build an Ugly Drum Smoker. You can find a drum for about $20-30. $10 in plumbing material, $10 in hardware, $15 for a thermometer, $20 a Weber grate, and about $25 in miscellaneous metal and you'd have yourself a great smoker. Another $10 in high temp spray paint if you want to make it a little prettier. I could help you with the hole locations for drilling. Making one is pretty easy. No welding necessary, just some drilling and some bolting together.
    Where are you located? Might even be able to loan one for a couple weeks ;).
  9. Sep 29, 2018 at 6:33 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    I'm in Fl. on the treasure coast. I want to get back into smoking again. I'm planning on smoking again. I've been broiling my hog shoulders in oven over the years I do good. I would have to do it in my driveway at the Villas it can't be a large smoker just a two a three rack stack one. And I'm gonna try smoking my lobster tails.
    bvbull200[QUOTED] likes this.
  10. Sep 29, 2018 at 6:38 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Bump the quote above by $30-40 to get a used Weber for a second rack and a domed lid. Lots of capacity in small footprint. I've been using drums for years.
    Boatbldr, Cold Iron and Kanyon71 like this.
  11. Sep 29, 2018 at 6:41 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    There should be some used ones around your area. Check craigslist.
    Boatbldr[QUOTED] and Cold Iron like this.
  12. Sep 29, 2018 at 6:49 AM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I first smoking salmon in Washington State a very long time ago. Alder was the wood of choice for fish then there and still is for me. And I think most people that do it a lot. It is mild and and IMO gives fish a perfect taste of smoke.
  13. Sep 29, 2018 at 6:52 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Love copper river smoke salmon and the candy strips. I get smoked black cod out of Sitka also. Buddy mails me a flat rate box quite often.
    Cold Iron[QUOTED] and Boatbldr like this.
  14. Sep 29, 2018 at 7:14 AM
    Cold Iron
    Mn.
    2013 AC T|X Baja
    One of these days before it is too late I really want to make a trip for the Copper River run. There is someone on here that lives in Alaska and does it every year, and when ever I mention it he says "I know a guy". It is on the bucket list!
    Kremtok and Bigdaddy4760[QUOTED] like this.
  15. Sep 29, 2018 at 7:45 AM
    la0d0g
    running for the hills
    For crawling not hauling
    $1/lb butts? Yes please.
  16. Sep 29, 2018 at 9:05 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    I have a old friend that runs a fish wheel. I is a super experience watching the wheel turn putting salmon in the box. But you will get tired of cleaning salmon.
    Cold Iron[QUOTED] likes this.
  17. Sep 29, 2018 at 10:06 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Where?? I must know.
  18. Sep 29, 2018 at 10:07 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Threw a few ribeyes on the smoker. If @Cooktop86 gets here on time, I may share a slice or two with him. Did one side with pitfaced, the other with SPOG. Changed plans after applying SPOG on the first side.
    Hobbs, Cold Iron, Kolunatic and 5 others like this.
  19. Sep 29, 2018 at 10:11 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    Man I'm getting hungry
    Kolunatic and WBF610 like this.
  20. Sep 29, 2018 at 10:12 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Me too. We didn’t have “lunch” food, so the steaks went on early.
    Boatbldr[QUOTED] likes this.
