Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 28, 2016 at 10:51 AM
    #2801
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Have any of you built around your smokers to help with cold, windy day smokes? Looking to build something for my upright but wanted to see if you guys had done so, could use some ideas and tips.
  2. Apr 28, 2016 at 11:09 AM
    #2802
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I've seen people build hinged screens out of plywood sheets and then cover the inside with the heat resistant foil insulation like goes around fireplaces. I'm lucky enough to have 2.5 sides of my smoker already surrounded because of the shape of my patio.
    wilcam47 likes this.
  3. Apr 28, 2016 at 11:49 AM
    #2803
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I thought about doing that with a prep station built around it.
  4. Apr 28, 2016 at 12:54 PM
    #2804
    drwx
    M'boro, TN
  5. Apr 28, 2016 at 1:38 PM
    #2805
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I just smoke in the garage. No worries about fire the smoker is insulated and the outside only gets warm to the touch:thumbsup: Then the garage will smells like smoked ribs (or whatever) for a week... no problem there!:cheers:
  6. Apr 28, 2016 at 1:47 PM
    #2806
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I used to use the cardboard box my first electric pill smoker came in. Tuck in and tape the top and bottom flaps. Then I could just collapse and fold flat for storage. I've used a beach towel and clothes pin with acceptable results. For a buddies we used 3 2'x4' pieces of plywood (1/2") connected with piano hinges, works great and folds flat for storage. I've always claimed wind was harder to deal with than cold. But with my current set up neither are an issue.
  7. Apr 28, 2016 at 1:49 PM
    #2807
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
  8. Apr 28, 2016 at 2:46 PM
    #2808
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    I'm smoking ribs again. Got the GF's parents in town and they're coming over for dinner. Only 2nd time I've met them. :goingcrazy:
    Anyway, just curious if anybody uses a rib rack? I bought this Weber from Home D but it's close to useless (1st pic). The ribs twist over and lay on top of each other. I have to keep adjusting them as they cook... I found the other one (second pic) on Amazon and it should arrive tomorrow. It's a much better design in that it supports the ribs nearly their entire length. With a few mods it should be near perfect.
    greeneggsnspam likes this.
  9. Apr 28, 2016 at 2:48 PM
    #2809
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    bottom rack looks nice
  10. Apr 28, 2016 at 3:45 PM
    #2810
    916carl
    Carl
    Yeah, bottom and middle are the same. I just bought that one on Amazon and it's coming in tomorrow. Won't help me with my ribs tonight but I'm hosting a spring BBQ on the day they have the Preakness and there will be about 20 people, so I need to maximize space. This one should do it...
  11. Apr 28, 2016 at 3:47 PM
    #2811
    Soflanick
    Nick
    FLORIDA
    yeah, looks it, depending on what size your weber is, i can fit 2 racks lying down on each rack.
    or you could fit more if you roll them they say...
  12. Apr 28, 2016 at 3:54 PM
    #2812
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I do use a rack. Can do 4 racks at a time easy. Mine has slanted slots. Put the ribs in meat side tilted back and the ribs lay out and open - no overlap. I'll try to find a link for you.
  13. Apr 28, 2016 at 3:55 PM
    #2813
    916carl
    Carl
    I have a CharGriller pellet cooker. It's a barrel shape (basically a copy of the Traeger Lil Tex, but bigger). It has a fair amount of space but the ribs I get at Restaurant Depot are pretty long - about 18 inches or so. I find if they get too close to the edges they burn/char, so the rack helps with that.
  14. Apr 28, 2016 at 4:01 PM
    #2814
    horstuff
    horstuff Re-member
    PNW
    Or you could use two of the HD cheapies side by side, and then you'd have shorter racks for when you might need them for whatever.
  15. Apr 28, 2016 at 4:29 PM
    #2815
    916carl
    Carl
    Could but I haven't needed to use it for anything else... Two of those are about the same cost as the Amazon one I just bought, but the Amazon rack is a much better design.
  16. Apr 28, 2016 at 4:31 PM
    #2816
    horstuff
    horstuff Re-member
    PNW
    I'm a newb to all this anyway, so that was just my newb suggestion. Is there any reason to not just cut the rib racks in half instead of trying to deal with them full length?
  17. Apr 28, 2016 at 4:52 PM
    #2817
    drwx
    M'boro, TN
    I roll mine up if I don't have enough room to lay them all out. You roll them to where the ends are overlapped but not touching and stick a couple of skewers through both ends.
  18. Apr 28, 2016 at 4:55 PM
    #2818
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I'm thinking about getting rib rack. Let me know how the Amazon one works out for you.
  19. Apr 28, 2016 at 5:01 PM
    #2819
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Don't buy a rib rack. Not if you have a roasting rack for your oven. The one you set your turkey in during the holidays. Just flip it upside down and use it like a rib rack.
    Sent via Jedi mind trick.
    bigfoote13 likes this.
  20. Apr 28, 2016 at 5:09 PM
    #2820
    la0d0g
    running for the hills
    For crawling not hauling
    I do this when space is at a premium.
