Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 7, 2019 at 4:45 PM
    Karate1993
    Karate1993 Well-Known Member
    coloRADo
    '14 TRD Off-road DCSB
    Did some pork belly burnt ends yesterday! Turned out really good. Not as much bark as I would have liked but the family still enjoyed them.
    wilcam47, JimboAnz, la0d0g and 11 others like this.
  2. Jan 7, 2019 at 5:15 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    My chimney looks about the same as the older one in the pic, not even certain of the brand. After watching the ads about the OJ one I got to thinking (dangerous). I drilled several holes in the side so it could breath a bit better (mine had nothing but the bigger holes only at the bottom. Day light and dark difference, I'd guess almost half the time to perfect coals. I'll be picking up the OJ model very soon, but some one may very well benefit from this simple mod.
  3. Jan 7, 2019 at 5:20 PM
    My Name is Rahl
    Ok, so I have a regular charcoal chimney. Not one of the fat, short ones. Should I drill holes in the side of it?
    wilcam47, burntkat and bvbull200 like this.
  4. Jan 7, 2019 at 5:57 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Don't know if you should, but I have the Weber unit he was talking about and am going to do the same thing to it.
  5. Jan 7, 2019 at 5:59 PM
    My Name is Rahl
    I just looked and mine is a Weber.
    bvbull200 likes this.
  6. Jan 7, 2019 at 6:00 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Does anyone know how to attach fire rope gasket material to a flat surface?
    Namely, I am trying to seal up my old offset smoker, having found the fire rope I bought for the purpose over a year ago. The firebox hatch is just like most of them, a curved affair that overlaps the hole in the drum by about a half inch per side.
    bvbull200 and My Name is Rahl like this.
  7. Jan 7, 2019 at 6:01 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    -drill sounds, a la Robot Chicken-
  8. Jan 7, 2019 at 6:02 PM
    My Name is Rahl
    High heat, fire resistant silicone.
  9. Jan 7, 2019 at 6:18 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Don't know your smoker, but that leak may be what is needed to keep the smoke from becoming creosote. I dunno.
  10. Jan 7, 2019 at 6:39 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Carburetion is done via the side of the box.
    CurtB[QUOTED] likes this.
  11. Jan 7, 2019 at 7:04 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So, add this to the list of food that Pitfaced spicy is good on...
    Baked sweet potatoes. I have started experimenting with them due to their supposed influence on blood sugar. Microwaved a very small one and added some butter and sour cream and a heavy dusting of Pitfaced spicy on one half, and Konriko Creole seasoning on the other. (I am wierd, eat skin and all of potatoes)
    They were both delicious. This will definitely go into the rotation.
  12. Jan 7, 2019 at 7:36 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Then you are sealing the lid to stop heat loss?
    I really shouldn't be commenting here, coz I don't use a smoker like the 1 you have. I bet you get it figgered out. ;)
  13. Jan 7, 2019 at 8:37 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Eating the skin of a potato isn't weird but microwaving them is :)
    wilcam47 and bvbull200 like this.
  14. Jan 7, 2019 at 8:38 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Somewhat, but mainly to control oxygen ingress to the fire. As it is presently, I can not choke the fire enough to gain control over it. This is why all my cooks thus far in this thread (until recently) have been in the oven. That will change soon as I figure out what I want to smoke next, which will be done in my new WSM (thanks again to Dan0mite).
    bvbull200 and WBF610 like this.
  15. Jan 7, 2019 at 8:39 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Hey, 5 minutes from raw to done, versus over an hour. I can't tell the difference in the final product (well if anything, the potato is creamier out of the microwave).
  16. Jan 7, 2019 at 8:44 PM
    la0d0g
    :der:You've never had a properly cooked potato then. There is no way to get crispy outside, soft inside via a microwave. No way, not happening.
    Plus I wear a :tinfoilhat: so I try to limit cooking via zapping.
  17. Jan 7, 2019 at 8:47 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I am all ears. What's the proper way to cook a potato?
    bvbull200 and la0d0g[QUOTED] like this.
  18. Jan 7, 2019 at 8:56 PM
    la0d0g
    I wash mine with a scrub brush and dry them off really good. Take a fork and stab them in two different spots, about 1/2 way through. Put them in a hot oven, 400 degrees for about an hour then wrap them in foil and let them cook until they feel right. Like they have that give where you know the inside is soft and cooked. Unfoil for five minutes with the door to the oven cracked. I do this with both russets and sweet potatoes and they turn out awesome. Sure it takes some time but that's time to fire up and cook on the grill.
  19. Jan 7, 2019 at 8:58 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So they go in the oven wrapped in foil from the start, right ?
  20. Jan 7, 2019 at 8:59 PM
    la0d0g
    No. First part unwrapped, then wrapped.
    wilcam47 and burntkat[QUOTED] like this.
