Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 8, 2019 at 2:01 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Speaking of potatoes, I will have to try this method...
    Or Hasselback potatoes: https://www.foodfunandhappiness.com/2013/07/secret-to-cutting-hasselback-potatoes.html
    bvbull200 likes this.
  2. Jan 8, 2019 at 2:36 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I'd let them season first.
    truchador, WBF610, bvbull200 and 2 others like this.
  3. Jan 8, 2019 at 2:44 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    I’ve always been told not to burn any green wood. Let it season. Not sure if it’s legit but I always erred on the side of caution.
  4. Jan 8, 2019 at 2:50 PM
    Dom Mazzetti
    Dom Mazzetti Well-Known Member
    Dom
    Myron Mixon uses green peach wood religiously. Never tried it myself but hard to argue with his track record.
    truchador and itzyoboipaul like this.
  5. Jan 8, 2019 at 2:55 PM
    TXTroop
    TXTroop Well-Known Member
    Matthew
    Texas
    2019 Cement TRD Sport 4x4 6MT
    Turkey breast on the traeger.
    wilcam47, grdgz97, truchador and 3 others like this.
  6. Jan 8, 2019 at 3:27 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Buttdate - butt has been pulled from oven. Suuuuper juicy and tender. Wrapped in some more foil and towels and in the cooler until dinner time
  7. Jan 8, 2019 at 3:39 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    I caught it and was going to say something, but can’t remember why I didn’t.
    Some do, but I prefer seasoned wood.
    this.
    Glad it turned out for you. Sorry for your troubles. It shouldn't be this hard.
  8. Jan 8, 2019 at 3:47 PM
    la0d0g
    running for the hills
    For crawling not hauling
    What temp did you get it up to? You going for pulled or chopped?
    uhplifted[QUOTED] likes this.
  9. Jan 8, 2019 at 3:55 PM
    uhplifted
    Brian
    16 DCLB OR
    Pulled! About 200
    Bigdaddy4760 likes this.
  10. Jan 8, 2019 at 3:58 PM
    uhplifted
    Brian
    16 DCLB OR
    Ya win some ya lose some. Just glad I was able to salvage this piece of meat. I know others aren’t always that lucky. I may have sneaked an early bite to taste test and it was goooood
    wilcam47, Cold Iron, CurtB and 2 others like this.
  11. Jan 8, 2019 at 3:58 PM
    la0d0g
    Nice. I leave mine in the cooler for about two hours and it turns out great.
    wilcam47, WBF610, burntkat and 2 others like this.
  12. Jan 8, 2019 at 4:01 PM
    uhplifted
    Brian
    16 DCLB OR
    Going to grab a few beers with a buddy and then will likely pull it when I get home. My NYE butt I think took an hour cooler nap and turned out really good too. Pulled pork tacos for dinner!
  13. Jan 8, 2019 at 4:10 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So the wife wants pork ribs out of the smoker next. So I will be firing up the WSM this weekend.
    Couple questions- fill the water pan, or run it dry and wrapped in foil? I know it serves as a heat deflector, but isn't the idea of the water to act as a heat sink? I know Harry Yoo says run Jr dry, but I am not at his level. So I need all to be weighed in my favor.
    Is the 3-2-1 rib process applicable to pork as well? Ie, 3 hours on the smoke, 2 hours in the crutch (foil wrap with liquid- and what kind?), then unwrapped back on the smoke for an hour.
    Wife got me a big box of smoking chips for Christmas. I have maple, peach, apple ,and cherry chips to chose from. I also have oak hunks I can use as well. Which should work best for pork ?
    Plan is to rub them with Pitfaced, one spicy one regular. I'm drooling already. .
    grdgz97 and bvbull200 like this.
  14. Jan 8, 2019 at 4:48 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Water will help control the temps, keep them low. Its hard to get the wsm over 240 with water in the pan. For your first time, I’d say fill it up. Then you can work towards not using it after you learn how the controls work on it. What type of ribs, spare or baby back? Baby back would be 2-2-1. Wood, I’d go apple and cherry. Try to get away from the chips in the future and use chunks. They last longer, and you don’t have to add them as much. Normally, 2-4 chunks is plenty for the entire smoke.
    Charcoal, you won’t need to fill the basket, 1/2 should be more than plenty.
    When you foil, and more rub, maybe brown sugar, and some liquid, you dont need much. I use apple juice.
    Good luck
  15. Jan 8, 2019 at 5:09 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Damn man. I'm a huge fan of my Traeger but watching what you're going through makes me feel like either I'm really lucky or their products aren't quite what they used to be. I know you've been back and forth both here and with customer service, but are you quite sure that you have ruled out operator error? Ask around here - I screw up plenty, so I hope you don't think I'm doing anything more than trying to help!
    As above, 2-2-1 for baby backs, 3-2-1 for St Louis. I don't have my WSM any more and I never got good with it, so I'll leave the rest to the pros.
    I use a maple-hickory-cherry blend for just about everything. So long as your rub is Pitfaced and your smoke is thin and blue, you will be just fine!
  16. Jan 8, 2019 at 5:10 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I'm glad you saved your butt. ;) I hope you have better luck with you next pooper. ;) ;)
  17. Jan 8, 2019 at 5:11 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    My go to recipe, but I may be biased.
    http://www.pitfacedbbq.com/competition-ribs.html
  18. Jan 8, 2019 at 5:16 PM
    uhplifted
    Brian
    16 DCLB OR
    100% sure not operator error. I don’t know what else I could possibly do. I clean the grill after every use. My pellets in this smoke were BRAND NEW I literally cut open the bag this morning to put them in the hopper. I made sure there was no air bubbles in there by stirring the hopper every 45 mins. Always had pellets in to keep it half full at minimum. Temperatures outside were mid 60s. No wind. I can’t think of a single possible thing I’ve done wrong. Did the initial firings as instructed per the manual. It just seems these 20 series are garbage.
  19. Jan 8, 2019 at 5:22 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    GMG :)
  20. Jan 8, 2019 at 5:35 PM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
