Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 10, 2019 at 7:31 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    You will find a bunch of us here make fatties. :). DAMN good eats.
    Was going to show you some pictures but I cleaned my phone off the other day and I don’t have them on here anymore.
  2. Jan 10, 2019 at 8:21 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I was looking for a happy dance gif, but thought this one was funnier.
  3. Jan 10, 2019 at 8:40 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    When smoking, once I get it thawed, rubbed, and waiting in the fridge to cook, I put a ziplock bag of crushed ice on the breast. It will tend to cook slightly ahead of the thighs, so doing this puts the starting temp lower than the dark meat. I like rubs on the sweeter side for smoked turkey. A little herbs helps, too (folks here know where my rub loyalties lie ;)). Injecting works wonderfully as well. You can get regular creole butter from most stores. Even if you aren't doing cajun spices, it works well. Place a little bit of rub under the skin so that the meat picks up some of the flavor. Don't go crazy, though, as that rub will cook in, but not cook off. A little goes a long way compared to rub on the outside of a pork shoulder. Brining is an option, but if it is an 'enhanced' turkey or one that is packaged in a water solution (most grocery store bought birds are that way), then I don't *personally* see a lot of upside, HOWEVER, there are some excellent brine recipes/tips from folks here that I'm sure can/will be shared.
    Cook it on the higher side of temps. 300-325* or so. I prefer a mix of pecan and cherry, but apple and maple are also AWESOME with turkey. Be mindful that turkey takes on smoke pretty easily, so you probably want to leave the heavier/harsher woods in the shed.
    You are going to want to probe two spots to tell when it is done. The first is the thickest part of the breast. You are looking for 165*. The second is the thickest part of the thigh. You are looking for 170*, but no sweat if it goes up to 175*. It is moist meat. 165* is food safe for turkey, so don't pull if either of those areas temps below that.
    Timing? It's usually about 3-3.5 hours for a turkey. An especially large one might be a bit longer and an tiny one a little shorter, but it doesn't vary much.
    Tent with a piece of foil for a few minutes when you're done, then get to carving!
  4. Jan 10, 2019 at 8:50 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Turns out it doesn’t have WiFi :pout:
  5. Jan 10, 2019 at 8:52 PM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    There's a Michael Scott for everything.
  6. Jan 10, 2019 at 8:57 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I’m sure I’ll be in the minority here, but I pull my poultry well before it ever hits 165 internally. The FDA recommends a 165 internal temp because at that temp 99.9999% of dangerous bacteria are killed instantaneously. But the pasteurization of poultry is a function of both temperature and time. You can achieve the same level of pasteurization if you hold the internal temperature at 150 for 3-5 minutes. And can actually safely pasteurize poultry all the way down to 140 if you hold it there for well over an hour.
    I typically pull once the bird has hit 155 and then has gone another few minutes. Taking a bird all the way to 165 makes it that much harder to keep it juicy and tender.
    Just my $0.02.
  7. Jan 10, 2019 at 9:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    CurtB[QUOTED] and Cold Iron like this.
  8. Jan 10, 2019 at 9:53 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    Used to have run applicants down to Military Entrance Station at Wilkes Barre, Pa. from Potter County and downtown Shinglehouse when I was on shore duty. Would have to leave at 0100 to have them on deck by 0600. Don't get me started, they all make me laugh and love Michael Scott. Even though Dunder Mifflin Paper Company was supposed to be in Scranton but was filmed in Cali, ugh. When office space and Michael Scott collide on a Multi Function Printer this is much truer to real life...
    No your not in the minority I mentioned it earlier :thumbsup: But yeah maybe we are in the minority, however I am used to that :D
    bvbull200[QUOTED] and burntkat like this.
  9. Jan 10, 2019 at 9:58 PM
    wilcam47
    Will
    Bourbon state
    Is the green piece on the top pic the antenna sticking out of the front? then the same looking piece on the pic in one below is the antenna hole? Then then black piece below that should plug the antenna (small end)? or am I looking at it wrong?
  10. Jan 10, 2019 at 10:12 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Laptops and cellphones, that is correct
  11. Jan 10, 2019 at 10:14 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    That appears to be a diagnostic ground. Not at all the connector.
    uhplifted[QUOTED] and wilcam47 like this.
  12. Jan 11, 2019 at 5:46 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    catching up now. @uhplifted sweet new rig!
    glad it didn't
    On a side note @Kanyon71 ... The wifi module for my damn pit is more than i thought...
    Eff that noise... I could almost buy a wifi enabled pellet rig from someone else?!?! I'm gonna email and ask what makes it so special other than it connects to a pricey pit... damn...
    gonna have to go DIY I guess. Off to search
    wilcam47, Cold Iron, Kanyon71 and 4 others like this.
  13. Jan 11, 2019 at 5:55 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Ribs may have to take a back seat this weekend- wife wasn't able to get to the store yesterday, and on the way to meet a friend, my @$%%&$%& truck decided to eject #4 cylinder (passenger side, middle) spark plug out of the engine entirely, taking the coil with it.
    Somewhere along the line before I got the truck, someone must have overtightened the plug into the aluminum head. I initially panicked, but then realized what was going on and remembered an old trick to keep chips out of an assembly when tapping a hole (in this case for a timesert/helicoil)- wheel bearing grease. Apply to the flutes of the tap, and take many shallow cuts. So I did so, taking 5, 1/2 turns each time before backing it out, wiping off the grease and chips, and spraying with brake clean before repeating. Took about 30 minutes of work, but went quite well. Luckily my son works at Oreilly auto parts, so I get his discount on parts- still a $120 job with the purchase of a coil, 6 plugs, 14-1.25 spark plug thread repair kit, grease, brake cleaner, and a ong-nosed blowgun to make sure I got all the chips out of the engine (though in fairness easily 99% of them were entrapped in the grease).
    Could have been sooo much worse. I was envisioning a $1000 repair bill, since it's a DOHC engine. Of course I'd do the work myself, but don't really have that kind of time at the moment. All the more reason to start upgrading my S10 so I can drive it if need be.
    But back to BBQ- I will have to go to the store today and see if I can find any decent racks left at Publix that aren't frozen.
  14. Jan 11, 2019 at 5:58 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Is that fake grass or do you fertilize like a mofo?
  15. Jan 11, 2019 at 6:32 AM
    Winker
    Winker Well-Known Member
    Paul
    Kentucky
    2019 Subaru WRX
    I wish my lawn looked like that this time of year :(
  16. Jan 11, 2019 at 6:38 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    God, yes. With all of the rain we have been getting, and the fact I live in what is basically a backfilled swamp, my grass is basically drowning in mud.
  17. Jan 11, 2019 at 7:01 AM
    la0d0g
    Between the dog and the snow, I feel ya!
  18. Jan 11, 2019 at 7:23 AM
    uhplifted
    Brian
    16 DCLB OR
    You’re probably looking at it wrong haha
    wilcam47[QUOTED] likes this.
  19. Jan 11, 2019 at 7:28 AM
    Winker
    Paul
    Kentucky
    2019 Subaru WRX
    It sure has been a wet winter so far. Unfortunately, I think we're going to get another round of rain this weekend. But that won't stop me from smoking some pork tomorrow.
    On the topic of dogs, I saw the satellite image of my home and my yard looks terrible!
    Cold Iron and la0d0g[QUOTED] like this.
  20. Jan 11, 2019 at 7:50 AM
    Kanyon71
    MI
    Ya I was looking at them trying to decide which one I would want and then went to accessories and saw the price. INSANE
    May need to figure out how to make your own board to go in it. Total BS that with the cost it doesn’t come built it.
