Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jan 12, 2019 at 10:54 AM
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    You'll always want the top vent 100% open and control temps with the bottom three. If temps stalled, start opening vents a bit more. You'll find that the WSM holds temp like a champ.
    Cold Iron and burntkat[QUOTED] like this.
  2. Jan 12, 2019 at 10:55 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Smoking today :smokertransformer:
    PF rubbed pork shoulder started about 3.5 hours ago 155f about to hit stall (maybe)
    Cold Iron, la0d0g, CurtB and 3 others like this.
  3. Jan 12, 2019 at 11:09 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
  4. Jan 12, 2019 at 11:10 AM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    You may need to start with more lit coals. I normally use about a 1/4 chimney of lit coal, which is about 15-20 briquettes. I start with the top completely open, and all the bottoms at 1/2 open. As it approaches target temp, i close off two completely.
  5. Jan 12, 2019 at 11:11 AM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Where’s the wood chunks?
  6. Jan 12, 2019 at 11:26 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Cold Iron and burntkat like this.
  7. Jan 12, 2019 at 11:32 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Picked up my Lumberjack Comp blend pellets at Rural King. $8.79 a bag for 20 lbs. picked up 4 bags for now. Got 80 lbs total $1 cheaper than I was paying for 40 lbs on Amazon. :thumbsup:
    uhplifted, bvbull200 and CurtB like this.
  8. Jan 12, 2019 at 12:14 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Spice for the ribs and some goodies for chili tomorrow.
    Kanyon71, Cold Iron, WBF610 and 3 others like this.
  9. Jan 12, 2019 at 12:18 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Wood chunks were soaking in water. Have a few on now.
    I already burned through a lot of that charcoal apparently. Wierd . Temp is around 250 right now, just adjusted the vents so I am going to see things are stable before adding meat.
    10 pounds of pork ribs. Cut each of the 3 racks in half, 4 of them are Pitfaced, 2 are Pitfaced Spicy. Can't wait to try them. If they taste as good as the PF tasted on my eggs this morning I will have to order larger portions next time.
    Kanyon71 and WBF610 like this.
  10. Jan 12, 2019 at 12:24 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So I ordered the food grade caulk tube to seal up my COS earlier this week....and the shipment was delivered yesterday...but it was a package of some sort of fruitybooty notecards. Way to fuck up my weekend, Amazon Returned. I will just get a tube from the Oreilly, and probably save money as well as I get a discount since my son works there
    Ordered a gasket kit from Amazon for my WSM. Hopefully it is actually in the box. I am sure it won't be an issue. Honestly, probably don't even need it, but it appeals to my controlling nature. ;)
    Temp appears to have settled in at 255. I shoveled in some more charcoal, out of Kingsford, have half a bag of Stubb's (correction, Cowboy) lump laying around. Hopefully I can get 3 hours at around 250 out of it.
    Stomach is growling... and we are probably looking at 10pm before the ribs are eaten. Grrrr..... they smell SOOOO GOOD and have only been on for a little bit.
    Edit- ribs on at 1530... and temps went up 20 degrees. Wtf?
    RickS and WBF610 like this.
  11. Jan 12, 2019 at 12:31 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    How long was it running to burn through that coal? A full load on mine will go 14 hours easy, at 225.
  12. Jan 12, 2019 at 12:46 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    About 90 minutes
    WBF610[QUOTED] likes this.
  13. Jan 12, 2019 at 12:53 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Lol. Tapped the top vent to ensure it was all the way open and the lid dropped a half inch with an immediate decrease in smoke leaking from where it meets the pit body . That is likely going to make a big difference....
    WBF610 likes this.
  14. Jan 12, 2019 at 12:56 PM
    nDub
    Lead Free Gasoline
    So much for a stall
    Five and a half hours in
    Threw some brats on for lunch:bananadance:
  15. Jan 12, 2019 at 12:57 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    You may want to try and get that door to seal better. Mine is not completely tight, but it does confirm to the smoker better. If you can’t get it worked out, cajun bandit had a door you can buy that’ll take care or it.
  16. Jan 12, 2019 at 12:58 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    There’s your problem!! Lol
    bvbull200 and burntkat[QUOTED] like this.
  17. Jan 12, 2019 at 1:10 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yessir, already tracking that. Seems I didn't secure it properly in the back of my truck and it got a bit battered. This pic was from after I bent it a bit to confirm better. I already have a new door in my order cart waiting to pull the trigger.
  18. Jan 12, 2019 at 1:12 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yup. Temp is swinging +/- 5deg now, around 245. It was as high as 275 for a bit. I am not going to sweat it if it stays between 225 and 275.
    Also should note that the dome gauge doesn't appear to be horrible.
    nDub, bvbull200 and WBF610[QUOTED] like this.
  19. Jan 12, 2019 at 1:23 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Give it 15-20 minutes between changes of the dampeners.
    My dome gauge is fairly on as well.
  20. Jan 12, 2019 at 1:36 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes, that is why I am doing this...
    WBF610[QUOTED] and bvbull200 like this.
