Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Dec 13, 2012 at 7:44 AM
    #301
    skb7527
    skb7527 Well-Known Member
    Scott
    McKinney, Texas
    2012 Pyrite Mica 4X4
    Goodyear Wrangler UltraTerrain AT tires with America Outlaw Sheriff wheels, Bilstein 5100s all the way around, OME coils, Toytech ICONS HD leafs, debadged, removed pin stipe, chopped tail pipe, weather tech floor mats, Leer color match topper, Toyota bed mat, homemade eight ball gear shifter and 4XInnovations weld on sliders
  2. Dec 13, 2012 at 8:24 AM
    #302
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Looks yummy. I think I can smell the goodness through the monitor. ;)
  3. Dec 13, 2012 at 2:42 PM
    #303
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    How was it. Looks really good!!! And how long was it on for?
  4. Dec 13, 2012 at 3:11 PM
    #304
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    It was good. Just slightly over cooked. It was cooking for 2.25 hours, then wrapped in foil and let sit for 15 minutes indoors
  5. Dec 13, 2012 at 8:22 PM
    #305
    toughtaco
    Nice thanks
  6. Dec 16, 2012 at 9:22 AM
    #306
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Wanted to try smoked chicken wings, and the local grocer had legs on stupid-cheap sale, so I put a dry rub on them yesterday and into the smoker today for a couple hours. I can already tell that the full coverage of the foil is hurting air flow a bit, even though I poked holes. The fire is going though, and I only had a few minutes of thick smoke before it settled down into the thin gray smoke that a hot fire gets you. Smoking over lump hardwood as usual for heat, with chunks of pecan and a few chunks of hickory for smoke.
    Here they are just before hitting the smoker.
    F0115EC6-A576-442B-A433-67D9F18A2848-241_ba36bbccd3331a0bcf02ffb25b6dc48a9b0cb3ca.jpg
    Would be better to have multiple levels for less crowding but you gotta do what you gotta do. 10 legs and probably 20 wing sections.
  7. Dec 16, 2012 at 2:25 PM
    #307
    toughtaco
    ^^^Can't wait to see them done
  8. Dec 16, 2012 at 2:42 PM
    #308
    Polymerhead
    Missouri
    Not much to show. They looked like BBQ chicken. Pretty disappointing results due to not enough fire. They basically smoked at 150 deg for a couple hours, with a mildly acrid taste, all due to the foil and crowding I think. Basically smothered the fire and got the wrong smoke for too long. Plus I really like the taste of hickory and the lighter pecan wood doesn't do it for me.
    I pulled them after 2 hours, threw them in the oven at 425 and crisped them up. Painted on a sauce made from spicy BBQ mixed with buffalo tabasco. Back in the oven long enough to thicken and lightly carmelize the sauce. They taste good, some pretty good BBQ chicken but not the smoked wings I wanted to make. I don't usually like to mask my food with a bunch of sauce, but it's a good method for covering up your mistakes. :)
    Will be good for lunches this week at work, just not the amazing results I had hoped for. Will try again with a hotter fire and less load on the rack.
  9. Dec 17, 2012 at 6:06 PM
    #309
    toughtaco
    I think that as long as they are not touching and you get the temp up before you put the meat on it you should be alright. At least that has been my experience. I usually keep it hot and smoking until I am done smoking what ever I have. I then let the temp go down and have a little fun like smoking marshmallows, they were good.
  10. Dec 17, 2012 at 8:12 PM
    #310
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Going to smoke my small brisket to prefect my technique for christmas tomorrow. Ill get of work at 4 and get a couple hours sleep then get up and start smoking at 10. I'm hungry already.
  11. Dec 18, 2012 at 12:56 AM
    #311
    toughtaco
    I did a 6 lb brisket for like 6 or 7 hours and it was delicious....... the best I ever had.
  12. Dec 18, 2012 at 6:26 AM
    #312
    Squirrel cage
    Squirrel cage Well-Known Member
    Sam
    Reno NV
    2016 DCSB TRD OFF ROAD
    Icon stage 4 lift,FN Countersteer wheels (16X8), 285/75/16 Duratracs
    Don't forget pics! (And tips) I've only done one brisket, and it was good, but not melt in your mouth good.
  13. Dec 18, 2012 at 10:42 AM
    #313
    FreidTaco
    FreidTaco boost
    jeff
    Well phone is currently out of commision because it is being used to stream a live video of my temperatures to the house... ifyou are interested you can watch my temps at http://www.ustream.tv/channel/jefffrei
    The left one is my smoker temp and my right one is meat temp.
    I am goint to wait until the meat temp hits 165 then wrap it in foil and keep cooking it until the perfect slicing temp of 185.
  14. Dec 19, 2012 at 10:58 AM
    #314
    Squirrel cage
    Sam
    Reno NV
    Haha. I think I'm a little late checking back. So, how did it turn out?
  15. Jan 9, 2013 at 3:12 PM
    #315
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Just bought myself a smoker :D
    http://www.amazon.com/gp/product/B00104WRCY/ref=oh_details_o00_s00_i00
    I have been looking at this one for awhile after it got recommended to me several pages back. The only place they had it in stock that I could find was Amazon, local or shipped. It should be here during next week. I'm gonna buy all accessories and chips and what not at cabelas because I have a gift card.
    Oh, and I got free shipping :D
    What to smoke first.... Suggestions?
  16. Jan 9, 2013 at 3:41 PM
    #316
    la0d0g
    running for the hills
    For crawling not hauling
    Congrats!
    I'd go with pork butt since its pretty forgiving. Just need to wait out the temp to jump from 165 to 195 for a good pull.
  17. Jan 9, 2013 at 6:53 PM
    #317
    Squirrel cage
    Sam
    Reno NV
    I second the pork butt. Not only is it forgiving, but pulled pork is always good!
  18. Jan 9, 2013 at 7:19 PM
    #318
    Forster46
    Nick
    Mount Vernon, WA
    I have written down the steps to make some different stuff. I viewed the page someone posted already about making the fatty. The write up is great but says nothing at all about what temp to cook or how long... Anyone have any ideas?
  19. Jan 10, 2013 at 6:29 AM
    #319
    Squirrel cage
    Sam
    Reno NV
    165*-170*
  20. Jan 11, 2013 at 4:18 PM
    #320
    ffnoahd
    ffnoahd Member
    sacramento, ca
    95 4wd taco
    Decided to smoke some turkey breasts today. About 3 hours and we will be good to go!!
