Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 9, 2019 at 8:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    theres a bite missing...;)
  2. Apr 9, 2019 at 9:02 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Snake method charcoal - Great for smoking!
    :D What Trigg uses. Should switch to Kerrygold, but it works :rofl:
    nobescare, nDub, WBF610 and 6 others like this.
  3. Apr 9, 2019 at 9:05 AM
    la0d0g
    running for the hills
    For crawling not hauling
    :fistbump:
  4. Apr 9, 2019 at 9:22 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    how long will those last ? my eyes tell me its not enough but how hot does that set up get?
  5. Apr 9, 2019 at 9:25 AM
    Misplaced Nebraskan
    Zach
    Austin
    at 225-250 it should last a full rib cook. depends on winds and yada yada, but I've gone 6+ hours on a setup like that. I do 4-5 briquettes though vice the three pictured. easy to add to the snake if it is running short too. slow consistent burn
  6. Apr 9, 2019 at 9:26 AM
    Misplaced Nebraskan
    Zach
    Austin
    will get as hot as you open the vents. easy to dial in low temps like this. For high heat cooks, the baskets work better
  7. Apr 9, 2019 at 9:28 AM
    fiftyxp
    do you control your temp with the bottom or the top? i usually just use the weber for grilling so I go full open top and bottom.
  8. Apr 9, 2019 at 9:33 AM
    Misplaced Nebraskan
    Zach
    Austin
    Try to control with bottom only and keep the top at least 50% open or more if possibly. keeping the top closed over will result in more creosote build up on food (potentially). usually the bottom vent is only barely cracked.
    I run the top open, bottom open to get temps coming up. When I gat around 200* i close the inlet back to barley open and start dialing in. once you get it, put a sharpie mark on the vent handle for ease starting point next time.
    nDub, la0d0g, FastEddy59 and 2 others like this.
  9. Apr 9, 2019 at 9:35 AM
    fiftyxp
    thanks for the tips
  10. Apr 9, 2019 at 9:38 AM
    Misplaced Nebraskan
    Zach
    Austin
    no problem. They are really good smokers once you learn them, which is usually your first cook
    Then you can start looking for a 26" kettle :D much more capacity. @bvbull200 and @itzyoboipaul can attest as well
    LxzMRBC7yCdgNXdlLmRGw2VanISt6jKW4m5XJ0Yr_53662df5df222c9c29f10496e6b2811fc6748ad1.jpg
    WBF610, wilcam47, la0d0g and 3 others like this.
  11. Apr 9, 2019 at 9:41 AM
    fiftyxp
    Yea I have the WSM and I use to use a chargriller smoker ( that thing was amazing) but after 4 years fell apart. Just never really smoked in the webber kettle.
    Since im doing ribs and brisket this weekend I figured it be great to have both going since mixing meats/times in the WSM is super inconvenient and messy.
    now you have to tell me your beans recipe. .. :cheers:
  12. Apr 9, 2019 at 9:42 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Now we're talkin' :cheers:
  13. Apr 9, 2019 at 9:42 AM
    Misplaced Nebraskan
    Zach
    Austin
    https://www.smokingmeatforums.com/threads/dutchs-wicked-baked-beans.50945/
    been my go to for years. Highly recommended!
  14. Apr 9, 2019 at 9:43 AM
    Misplaced Nebraskan
    Zach
    Austin
    that too :rofl: gotta have booze!
  15. Apr 9, 2019 at 9:45 AM
    fiftyxp
    hopefully this weekend I can make everyone here jealous for a change..who am I kidding will probably be a disaster.
  16. Apr 9, 2019 at 9:47 AM
    Misplaced Nebraskan
    Zach
    Austin
    Confidence! Just don't overthink it and have some beer/scotch/whiskey :thumbsup:
    fiftyxp[QUOTED] and FastEddy59 like this.
  17. Apr 9, 2019 at 9:50 AM
    fiftyxp
    instructions unclear, burned house down.
  18. Apr 9, 2019 at 9:50 AM
    Misplaced Nebraskan
    Zach
    Austin
    too much beer/scotch/whiskey likely :rofl:
    FastEddy59 and fiftyxp[QUOTED] like this.
  19. Apr 9, 2019 at 9:52 AM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Even my worst BBQ still came out pretty decent. If no one throws up then it was a success.
  20. Apr 9, 2019 at 9:56 AM
    fiftyxp
    yea no im joking ill do fine, i just know how it goes with a first time smoker, doesnt always come out good the firstime until you figure out how it cooks.
    I need this one to come out a little better than a first time though, and ribs are pretty easy most of the time.
    Misplaced Nebraskan likes this.
