Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Apr 15, 2019 at 10:33 AM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    deal! just need to plan my trip up there. May is pretty open so far. just one weekend I have on call. will get with you and @bvbull200 on that :thumbsup:
  2. Apr 15, 2019 at 10:33 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Sounds great
  3. Apr 15, 2019 at 10:52 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I go with what takes the least amount of work So that’s keeping it whole lol.
  4. Apr 15, 2019 at 10:52 AM
    Misplaced Nebraskan
    Zach
    Austin
    very valid reasoning!
    K.I.S.S. method :thumbsup:
  5. Apr 15, 2019 at 11:13 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    For comps, you aren't allowed to fully separate the two, but you can do a really aggressive trim that, for all intents and purposes, leaves you with two separate pieces - they are just connected by a small bit to still technically be whole.
    I've done that, then turned the two pieces 90 degrees from each other so that they were pretty much separate. Cook time really doesn't change and the results for the "good" parts of the flat don't really change, either. A little extra bark and flavor for the newly exposed bit of the flat. The part of the flat that tends to get narrow and a little thin dries out a bit. I like that part when I can cut a slice that is part flat, part point. You kind of lose that when separating. I'd consider trimming aggressively (comp style), but leave it mostly in its original form while doing most of the cook, then separating near the end so you can really dial in each bit of the brisket for what you're going for. It's a fair bit of work for minimal results (in my opinion), but if you have the time to squeeze out every bit of result, it might be worth sticking it in your repertoire.
  6. Apr 15, 2019 at 11:19 AM
    Misplaced Nebraskan
    Zach
    Austin
    Good point about the comp bits. I'm already an aggressive trimmer...(ask @Bigdaddy4760 ... I make him nervous :rofl:) but not comp level. I need to start messing with that though to get some skillz!
    lYw5cwxkdXW6o5eNxrvqEVKSWe9KJSFyrdWL4uAh_b604b40de9e8569ddb4017ced9e058c1cf9b2c7c.jpg
  7. Apr 15, 2019 at 11:21 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    I would say you are right at comp level now.
    :D
  8. Apr 15, 2019 at 11:24 AM
    Misplaced Nebraskan
    Zach
    Austin
    I haven't shaped them yet... just trim the fat :rofl:
  9. Apr 15, 2019 at 11:38 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    KCBS, you can trim the slices to fit the box after the cook. IBCA, you have to trim the width of the brisket to size before the cook, so when you cut your slices, they have to already fit in the box. I still shape them ahead of time for KCBS so that the slice has bark/a smoke ring all the way around it :D
    If the grain runs across the length of the flat as opposed to along that direction, you end up with some funky shaped briskets :rofl:.
  10. Apr 15, 2019 at 11:41 AM
    Misplaced Nebraskan
    Zach
    Austin
    yeah I've started researching comp trims and shaping with the right grain to get the money slices. Figure I can smoke up the scraps for chilis and nachos
    Kanyon71 and Bigdaddy4760 like this.
  11. Apr 15, 2019 at 11:46 AM
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    Here is one I did pretty aggressively. You can tell the flat is squared up (nearly) perpendicular to the grain to get as many right-sized slices as I can. This one had a grain running the "good" direction.
  12. Apr 15, 2019 at 12:18 PM
    la0d0g
    running for the hills
    For crawling not hauling
    My wholes turn out way better than just one or both separated. I haven't questioned why, I just do wholes now :D
    reefclimber, WBF610, nDub and 4 others like this.
  13. Apr 15, 2019 at 2:32 PM
    Misplaced Nebraskan
    Zach
    Austin
    2 for work 1 for me. Those bastards get prime too!
    10.64 and 10.76 lbs.
    Then a 7.25 lber for me. Love the little sub 8 lb ones. Couldn't pass it up.
    wilcam47, WBF610, relkins0413 and 7 others like this.
  14. Apr 15, 2019 at 2:35 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Butcher shop just sent out there e-flyer. Brisket at $8/lb. Order Placed. :yay:
  15. Apr 15, 2019 at 2:37 PM
    Misplaced Nebraskan
    Zach
    Austin
    Is That gold wagyu?! :p
    I might be able to ship to you cheaper....
    Oh... Canada. Maybe not.
  16. Apr 15, 2019 at 2:41 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    You must really like your co-workers. lol
  17. Apr 15, 2019 at 2:43 PM
    FastEddy59
    Eddie
    No, but the quality is top shelf. I've never had to take anything out back to soften it up from that shop.
  18. Apr 15, 2019 at 2:50 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Really wonder what it would cost to ship to me. Might be worth it when you all get those silly low prices.
  19. Apr 15, 2019 at 2:54 PM
    Misplaced Nebraskan
    Zach
    Austin
    I like my reputation more :D . But 3.39/lb
    Excellent! How much you get?
    I can get some quotes for sure for ya. I froze one and sent it to VA to my cousin. Think it was $20-$25 for a 15 lb plus some other small items.
  20. Apr 15, 2019 at 3:03 PM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Guess who just scored a FREE kettle on the way home from work? That’s right, me! It was just sitting at the edge of the road, I pulled up and dude was power washing his boat...gave me a thumbs up and I threw it in the back of the truck :headbang:
    This kinda stuff never happens so I’m probably more excited than I should be haha. Looks like a standard 22, so it’ll join my other “higher end” 22 :D
    DETaco17, wilcam47, DiamondW and 11 others like this.
