Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jul 10, 2016 at 5:51 PM
    #3561
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    How did we do?
  2. Jul 10, 2016 at 8:21 PM
    #3562
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    GF had last minute plans so for dinner I had to fend for myself. Luckily I had a pork chop in the freezer. A bit of pork rub then on the smoker in Smoke mode for an hour with a little help from the smoke tube and apple wood. After an hour turned up the heat until IT hit 130 then I pulled it. Cranked smoker to high and put the chop on the grill grate with some honey bourbon glaze until I got an IT of 140.
  3. Jul 10, 2016 at 8:23 PM
    #3563
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Looks good.
  4. Jul 10, 2016 at 9:14 PM
    #3564
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Haven't went yet, going tomorrow. Was wondering if you think the ash bowl needs holes drilled. Dry run today, was able to hit and keep 300 for 2.5 hours with full chimney, no damper at bottom. So, I figure I can hold 225 for 4 hours with one full chimney and a bit of damper.
  5. Jul 10, 2016 at 11:30 PM
    #3565
    t4daddy
    North Alabama
    Good on you for doing a test run, plus you seasoned it to some degree.
    bigfoote13 likes this.
  6. Jul 11, 2016 at 12:52 AM
    #3566
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I didn't remember any holes or drilling holes in the ash bowl.
  7. Jul 11, 2016 at 3:38 AM
    #3567
    t4daddy
    North Alabama
    You said "ash bowl"....
  8. Jul 11, 2016 at 5:26 AM
    #3568
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    I used to have one of the rectangular brinkmann smokers with the 2 doors. I replaced the original charcoal basket with one of the square grill woks at Lowe's. It fit perfectly and greatly improved air flow. I stuck the original one on the floor of the smoker. Without the holes, the charcoal ash won't fall away and will eventually just smother the charcoal on longer smokes.
  9. Jul 12, 2016 at 8:41 AM
    #3569
    George P. Burdell
    George P. Burdell THWG
    Upstate, SC
    14' MGM PreRunner.
    Just a few minor things.
    My first go at some chicken lolli's. Also made my own dry rub for the first time. They were a little spicier than I like, so I might have to tweak my rub recipe a bit. 3.5hrs on the smoker and just under an hour on the grill over indirect heat. Cooked through perfectly. :cheers:
    0711161443.jpg 0711161554.jpg 0711161711.jpg 0711161721.jpg 0711161734.jpg 0711161815.jpg
    grdgz97, robssol, Woundedyak and 4 others like this.
  10. Jul 12, 2016 at 9:17 AM
    #3570
    la0d0g
    running for the hills
    For crawling not hauling
    Frenching like a mofo.
    scottalot[QUOTED] likes this.
  11. Jul 12, 2016 at 9:21 AM
    #3571
    la0d0g
    Agreed :hungry:
  12. Jul 12, 2016 at 10:05 AM
    #3572
    Papichulo
    Papichulo Well-Known Member
    Sutter Buttes
    Has anyone smoked meat balls?
  13. Jul 12, 2016 at 10:16 AM
    #3573
    George P. Burdell
    Upstate, SC
    14' MGM PreRunner.
    This ^^^ and removing tendons. Also removed another smaller bone.
    sjwhitaker and scottalot[QUOTED] like this.
  14. Jul 12, 2016 at 6:34 PM
    #3574
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Damn, been missing out I'm this thread. I'm in now.
    M192 and Polymerhead[OP] like this.
  15. Jul 12, 2016 at 6:51 PM
    #3575
    Papichulo
    Sutter Buttes
    image.jpg image.jpg image.jpgI may be a newbie to smoking but not to making fire roasted salsa.
    Hobbs, grdgz97, wilcam47 and 2 others like this.
  16. Jul 12, 2016 at 7:50 PM
    #3576
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Well?
  17. Jul 12, 2016 at 8:05 PM
    #3577
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Sweet just found this. I've been smoking on the grill for the past two years. I just got a bigger empty can of chicken kept the lid. Fill it with wet apple or hickory chips and put the lid back on and set it ontop the grill burner. Worked pretty well. But I wanted something bigger and I'm cheap so I built my own. I'm in it about 2-250$. Used it for ribs twice. I can fit 4-5 beef racks in it. Idk how many pork. I have LP on it in case I couldn't get the temp up with the charcoal. But it worked soo I took the tank off. image.jpgimage.jpg image.jpgHere is two beef racks and a pork rack I did last weekend. I believe I'm gonna go with mostly pork now. Maybe 3 pork one beef. image.jpgThat's after three hrs smoking was getting ready to wrap for two more hrs. I know I know I don't have the meat on the grate it's on foil in aluminum pans. I like my shit clean with minimal clean up. After every run I spray everything down with vegetable oil to "season" it.
  18. Jul 13, 2016 at 6:08 AM
    #3578
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    Just did some this weekend. 1:4 ratio cut with ground pork
  19. Jul 13, 2016 at 6:13 AM
    #3579
    Woundedyak
    Indy
    Well done your lollies look great. IMO your times are a little long. In the pan with butter for 2hrs at 300. Dunk in glaze then back on the grill with out pan for 1/2hr or glaze sets up. Won't even half to chew. They will dissolve in the pie hole
    scottalot likes this.
  20. Jul 13, 2016 at 11:46 AM
    #3580
    George P. Burdell
    Upstate, SC
    14' MGM PreRunner.
    These things couldn't have been cooked any better. Meat fell right off the bone. Like I said before, I just need to tweak my rub a bit. I'll use less charcoal next time... try and keep the temp down around 225-250. I love longer cooks. Might even up it from one to two dozen drums.
