Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jun 24, 2019 at 12:14 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Lot's of people finish in the oven. I've done it a few times too. Opposite of what you've posted obviously but there's multiple paths to the finish line.
    Do you wrap at all? time under heat and smoke is what sets the bark. we all range from low and slow to hot and fast in here. I prefer low and slow and not wrapping if I can help it. If I do have to wrap, I try and make sure the bark is set up enough (fingernail test) before wrapping. And then i'll alternate between foil and butcher paper, depends what I have on hand.
    Main thing is do what you like and what works for you. for the 18 lber, it could be done low or hot. could do 225 ish on the pit for 4-6 hours for good smoke, wrap and in the oven at 250-275 to finish. depends on your timeline though.
  2. Jun 24, 2019 at 12:15 PM
    Misplaced Nebraskan
    Zach
    Austin
    It's in the mail already.
    I'll probably have more stuff once my new probes arrive though :rofl:
    Wixo[QUOTED] and Bigdaddy4760 like this.
  3. Jun 24, 2019 at 12:17 PM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    OKOK, I guess Ill give it a little less time in the oven and a little more in the pit.
    I only wrap it when I put it in the oven.
    Another thing I do is Ill put a small metal tray with all of the juice it released in the oven under the brisket. I do it in hopes of keeping everything moist, whether it makes a difference or not is another thing.
  4. Jun 24, 2019 at 12:20 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Havent done brisket. But with the chuck roast (close to the same) i had been doing 6 hours on the smoker then wrapping in foil to finish off in the oven until 200-205ish. Depends if you want it sliced or pulled. Bark has been tasty for being done in an electric smoker and it retains a lot of moisture after being wrapped.
  5. Jun 24, 2019 at 12:22 PM
    Misplaced Nebraskan
    Zach
    Austin
    I think pit first then oven may yield a better flavor. More smoke absorption and reaction in the initial cook times. up to about 140°F ish. Then after that it's just bark formation. Once it's wrapped, in foil anyway, heat is heat. if you use butcher paper, some added moisture via a pan is good choice. Ovens are pretty dry.
    Main thing is to just tweak your method. Sounds like you are close to what you like so just chasing that last leg is tough. If you change it all up could be a longer journey. Fun journey though.
    Just don't forget pics :thumbsup: @Bigdaddy4760 gets unruly... :D
    Cold Iron, WBF610, Kanyon71 and 2 others like this.
  6. Jun 24, 2019 at 12:25 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Getting some good stuff ready for a cook soon
  7. Jun 24, 2019 at 12:37 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Bear? :D
    Misplaced Nebraskan likes this.
  8. Jun 24, 2019 at 12:39 PM
    Misplaced Nebraskan
    Zach
    Austin
    :woot:
    He does frequent Alaska... :D
  9. Jun 24, 2019 at 12:40 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Well, at least you ain’t boilin’ nothin’. :facepalm: It’s all dry heat.
  10. Jun 24, 2019 at 12:49 PM
    Wixo
    Hank
    Tint, LED interior
    I have it in the oven for a few hours, and then I take it out to the pit to finish. I use an almost identical set up to what the guy in the video does. The pan I put under the brisket is all brisket juice and I use mesquite wood. The only par Im missing is that bark. https://youtu.be/ocQ9nEjsFEY
    WBF610 and FastEddy59[QUOTED] like this.
  11. Jun 24, 2019 at 12:50 PM
    Wixo
    Hank
    Tint, LED interior
  12. Jun 24, 2019 at 12:51 PM
    Misplaced Nebraskan
    Zach
    Austin
  13. Jun 24, 2019 at 2:07 PM
    FastEddy59
    Eddie
    Just tryin’ to decide, Regular or Wagyu butter. :notsure:
  14. Jun 24, 2019 at 2:35 PM
    Misplaced Nebraskan
    Zach
    Austin
    Cold Iron and FastEddy59[QUOTED] like this.
  15. Jun 24, 2019 at 3:21 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Got this for Friday
  16. Jun 24, 2019 at 3:46 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Think you need to try pit first then oven like suggested :notsure:
    Wixo[QUOTED] likes this.
  17. Jun 24, 2019 at 3:57 PM
    Wixo
    Hank
    Tint, LED interior
    Does anyone have experience doing pit only?
    Bigdaddy4760 likes this.
  18. Jun 24, 2019 at 3:59 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    40 years worth but with stick burners
    la0d0g, t4daddy, bvbull200 and 3 others like this.
  19. Jun 24, 2019 at 4:10 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    My brisket never hits the oven. Done full time in the pellet pooper. I’ve also stopped wrapping it at any point. Been liking the results more and more each time I do it.
    wilcam47, TK-422, Cold Iron and 4 others like this.
  20. Jun 24, 2019 at 4:42 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    As Zach suggested, do it on the pit first for smoke flavor, and start the bark. If you want a nice bark, wrap with paper or leave it unwrapped.
    Cold Iron, Kanyon71 and FastEddy59 like this.
