Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jul 23, 2016 at 9:36 PM
    #3721
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    So should I trim the fat cap? Will the rub be wasted if I don't?
  2. Jul 23, 2016 at 9:45 PM
    #3722
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I usually trim the fat cap down to 1/4"
    robssol likes this.
  3. Jul 24, 2016 at 8:01 AM
    #3723
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    This is an almost universal recommendation, and I agree. If you buy a flat in the store, it's usually already trimmed.
  4. Jul 24, 2016 at 8:55 AM
    #3724
    wilcam47
    Will
    Bourbon state
    walmart's whole brisket usually has a good layer of fat, I trim down the thickest fat and apply the rub.
    Have you tried just a basic salt pepper and smoke on a brisket? I saw one show on tv they did that I may try it out on the next brisket I make.
  5. Jul 24, 2016 at 9:41 AM
    #3725
    Polymerhead
    Missouri
    I agree 100% that you should trim a packer brisket. When he mentioned he was smoking a flat I didn't want him to be confused. I didn't read back enough to see if he was cutting the flat himself or buying a separated flat.
    I've definitely done a straight S&P rub on brisket. It was good, and really "beefy" tasting. Honestly I like it better with some onion powder, paprika and even some brown sugar in there.
    wilcam47 likes this.
  6. Jul 24, 2016 at 10:42 AM
    #3726
    horstuff
    horstuff Re-member
    PNW
    Water in the pan?
    Wrap?
  7. Jul 24, 2016 at 11:23 AM
    #3727
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Water in the pan depends on the cook. Some people do it, some don't. Usually more experienced people do without the water. Temp control is easier with water since you essentially have a massive thermal mass (the water) that is slow to heat up and cool down.
  8. Jul 24, 2016 at 11:27 AM
    #3728
    la0d0g
    running for the hills
    For crawling not hauling
    I had some jalapeno elk sausage so I decided to make a fatty with it. Stuffed with marion blackberry preserves and gorgonzola. Wrapped in bacon. Some bold flavors in there so its either going to be awesome or a big fail.
  9. Jul 24, 2016 at 11:31 AM
    #3729
    Polymerhead
    Missouri
    Wrap once you hit the stall, in paper. Don't wrap in foil. You want to minimize the "boiling" of the meat that you get by wrapping too tightly. I've done my last couple in paper grocery bags and it works great, though some folks worry about chemicals in the bags leaching out.
    My tip, take it or leave it - once you are into the stall, consider bringing it inside and finishing in the oven at 220 or so. Easier to watch, more controlled temps and less air flow to dry out the meat, especially with a flat alone.
  10. Jul 24, 2016 at 11:40 AM
    #3730
    horstuff
    horstuff Re-member
    PNW
    For a 5 pound flat (got it from the store already cut) at 225, roughly how long until the stall? I only have one probe therm, which lives near the grate, so my only way of checking the meat temp is to open the lid and insert my instant read.
    All I have is grocery bags, so that'll have to do. Maybe just put the meat in a whole bag and fold closed, no bag trimming?
  11. Jul 24, 2016 at 11:50 AM
    #3731
    Polymerhead
    Missouri
    Call it 4 to 6 hours, depending on moisture content. If I had your setup, I'd tend the smoker to keep the temp at 225 or so for about 5 hours or until I was bored, then I'd move the probe to the meat, wrap, put it in the oven on a pan rack over a pan at 220 and forget about it until the meat registered 200 or just under. Then simply turn off the oven and leave it wrapped for an hour or so. It's just as good as a cooler rest and you don't lose the moisture in the meat by unwrapping.
  12. Jul 24, 2016 at 12:04 PM
    #3732
    horstuff
    horstuff Re-member
    PNW
    Would you use water in the pan? Right now I have the pan wrapped in foil.
  13. Jul 24, 2016 at 12:19 PM
    #3733
    horstuff
    horstuff Re-member
    PNW
    I decided no water. Here we go...
  14. Jul 24, 2016 at 12:29 PM
    #3734
    Polymerhead
    Missouri
    Water is great if you need thermal mass. I don't use water in my Akorn because it holds steady temps really well without it. When I used a keg smoker, I used water more often because it was thinner material and didn't have a lot of mass to hold heat.
  15. Jul 24, 2016 at 12:40 PM
    #3735
    horstuff
    horstuff Re-member
    PNW
    When at stall, just open paper grocery bag, insert brisket, close bag?
  16. Jul 24, 2016 at 5:01 PM
    #3736
    la0d0g
    Turned out pretty good. The wife likes it more than me since its a bit on the sweet side.
    grdgz97 and truchador like this.
  17. Jul 24, 2016 at 5:06 PM
    #3737
    Polymerhead
    Missouri
    Yup.
  18. Jul 24, 2016 at 5:45 PM
    #3738
    horstuff
    horstuff Re-member
    PNW
    It's been 5 hours at 225. 5 pound flat. Temp at thickest part is 140. I just put it in grocery bag and closed it. I know it's supposed to be more like 160 (?) but I gotta go mow neighbors yard and wanted to be done for now. Should still be ok after a couple more hours, eh?
  19. Jul 24, 2016 at 6:28 PM
    #3739
    Polymerhead
    Missouri
    You'd be surprised. It might take 10. It's done when it's done - that's why I bring mine in and oven finish. At some point you have to get other stuff done.
  20. Jul 24, 2016 at 7:01 PM
    #3740
    horstuff
    horstuff Re-member
    PNW
    Woof. This brisket bidness is a commitment. You're right, I would be surprised. An hour fifteen later and meat temp is still just 152. Wtf. I'll do your oven idea in about half hour. 220 until just under 200, leave it in the bag the whole time. Correct?
