Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Jul 19, 2019 at 3:49 PM
    la0d0g
    running for the hills
    For crawling not hauling
    :jellydance:
    FastEddy59 likes this.
  2. Jul 19, 2019 at 4:19 PM
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Smoked and then seared. Unicorn on the top and Seasoning Salt on the bottom.
    RickS, la0d0g, 12thmanhawkfan and 9 others like this.
  3. Jul 19, 2019 at 6:40 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Alright, got it seasoning as of an hour ago. Sprayed everything down with olive oil inside and got some Kingsford and hickory in it.
    Door leaks some but I’m taking everyone’s advice and seeing how temperatures maintain before I do anything about it. Might be just fine.
    TK-422, wilcam47, oscolivar1 and 6 others like this.
  4. Jul 19, 2019 at 7:46 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    When I first started smoking I had the $30 brinkman smoker . Leaked like hell but worked ok . Just used more charcoal and wood . Yours looks way better than the brinkman I had . Enjoy :thumbsup:
  5. Jul 19, 2019 at 7:50 PM
    SwampYota
    Jon
    Floor mats
    I checked the weather on the phone before I fired this thing up, no chance of rain...two hours later random thunderstorm!
    No rain yet hopefully it holds off.
  6. Jul 19, 2019 at 8:11 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    NY strips bout to go on
  7. Jul 19, 2019 at 8:30 PM
    uhplifted
    Brian
    16 DCLB OR
  8. Jul 19, 2019 at 9:30 PM
    RiskDude
    RiskDude Well-Known Member
    So Cal
    21 DC OR Army Green
    Does a Tail Gate Lock Count?
    I posted this on the Smoking Meats forum, but thought I would share here too... I have been reading about the Blackstone griddles and decided to see if I could make one.
    Went to the local metal store and bought a piece of sheet steel and some side pieces, measured, cut, drilled, and BAM... BBQ griddle.
    Seasoned it up:
    Couple things that are not perfect. If the heating is uneven, it will warp. It is just sitting on some steel tube risers so it is not setting on the grate. Heats up quickly and holds heat well, even though it is less than 1/8 inch thick. Gotta figure out a drippings solution though.
    Tested it this evening with bacon, onion and turkey. Ended up making chopped turkey/bacon/onion sammiches..
    I was actually surprised that a) it worked, and b) it tasted good!! Tomorrow is the pancake test. Not bad for $35.
    rob1208, oscolivar1, la0d0g and 14 others like this.
  9. Jul 19, 2019 at 11:58 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Good old steak and potatoes day.
  10. Jul 20, 2019 at 12:06 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I wonder if that big metal box they are in is acting like a Faraday cage.
    wilcam47 likes this.
  11. Jul 20, 2019 at 2:06 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Love my blackstone!
    To help the potential warping....mine has bars across the bottom. I guess that helps that? :notsure: I’m no design engineer.
    Also, maybe you can notch out the front right corner somehow and hang one of them grease buckets like a traeger?
    medic2230, Kanyon71 and wilcam47 like this.
  12. Jul 20, 2019 at 7:03 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  13. Jul 20, 2019 at 7:04 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    :hattip:
    wilcam47[QUOTED] likes this.
  14. Jul 20, 2019 at 7:04 AM
    Kanyon71
    MI
    If there was no signal at all I could see it but dropping and reconnecting consistently is a sign of bad design or code usually.
  15. Jul 20, 2019 at 7:05 AM
    wilcam47
    Will
    Bourbon state
    Morning! just getting my morning fix of coffee and bbq'in this morning...;)
    Bigdaddy4760[QUOTED] likes this.
  16. Jul 20, 2019 at 7:06 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    What's on the menu for today.
  17. Jul 20, 2019 at 7:13 AM
    wilcam47
    Will
    Bourbon state
    Nothing big, may throw some elk steaks on the grill;)
  18. Jul 20, 2019 at 7:54 AM
    wilcam47
    Will
    Bourbon state
    you got anything going? You out of state?
  19. Jul 20, 2019 at 7:54 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    I am at work. :(
  20. Jul 20, 2019 at 8:00 AM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
