Food Smokers and Smoking Tips/Tricks/Techniques
Discussion in 'Food Talk' started by Polymerhead, Jul 15, 2012.
  1. Aug 3, 2016 at 8:38 AM
    #3881
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    For those of you with smoking experience. I have been playing around with slow grilling ribs, brisket, and pork loin (whole). I have been using charcoal and hickory wood chips. While all the meat has turned out great in terms of tenderness, I personally am not a fan of the smoke flavor. It's very intense, like I just smoked a cigarette on top of eating a cut of meat.
    I like ribs and BBQ I get at restaurants and I know that stuff is usually smoked. So what is making the overwhelmingly smoky flavor? Could I use plain charcoal and no wood chips for a milder flavor?
  2. Aug 3, 2016 at 8:41 AM
    #3882
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Too much wood? Really, a little goes a long way. Also, you don't want dark billowy smoke. Just what they call, thin blue smoke.
  3. Aug 3, 2016 at 8:43 AM
    #3883
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Exactly this. Little smoke that is flowing. Heavy smoke that just sits there will get you that ashy taste.
  4. Aug 3, 2016 at 8:44 AM
    #3884
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    also depends what you are cooking/grilling...theres a few different woods to use for smoking not just hickory. try some different ones on different meats
  5. Aug 3, 2016 at 8:54 AM
    #3885
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I like your make shift fut you might want to in the Amazen Pellet tube in the links in the discussed products. So much simliar and easy to use.
  6. Aug 3, 2016 at 9:16 AM
    #3886
    916carl
    Carl
    Big fingers little buttons? Just kidding but I think what you're getting at is a recommendation to use the amazen smoketube? If so I am using the 12" one - it's in the mailbox. Combo apple and hickory dust and pellets.
    Right now I'm dialing in the mailbox door opening and Weber lid vents to regulate the airflow and amount of smoke. Too much air gets the pellets smoldering too much and that means too much smoke (ashy taste). Too little and the pellets go out. It's trial and error but kinda fun.
  7. Aug 3, 2016 at 9:25 AM
    #3887
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    I used Apple with Extraordinary results the last time I did a butt
    scottalot likes this.
  8. Aug 3, 2016 at 9:34 AM
    #3888
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    Try getting away from the hardwoods and go with apple,cherry, or peach
    Boerseun and scottalot like this.
  9. Aug 3, 2016 at 10:27 AM
    #3889
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Holy shit that was awful. Sorry.:crazy:
    When i use the tube for smoke i don't really care about the air flow. I light the pellets, let the fire burn for a bit, blow out the flame, put on the lid and walk away. I've never had the fire light back up just smolders. I use a 26 webber and I have the bottom half open and the top wide open.
    Jope dis phelps....:crapstorm:
  10. Aug 3, 2016 at 1:20 PM
    #3890
    916carl
    Carl
    :rofl::thumbsup:
    Stupid autocorrect.
    I've cold smoked cheese and it came out ashy. Big waste of time and money. I didn't want a repeat. I put the tube in the mailbox to try and keep the temps down in the Weber. I figured 8 hours of smoke but chickened out at 5 hours and pulled it. Partly because the temps in the Weber were rising (when it hit 70f that was it) and also I didn't want to risk ashy taste. I'd rather have it a bit milder and edible vs. cigarette flavored bacon.
    Anyway, it's in the refer cooling down now. I'll slice some off in a couple hours and do a test fry. If it's acceptable then I'll slice up the rest and vacuum seal/freeze most of it.
    bigfoote13[QUOTED] likes this.
  11. Aug 3, 2016 at 1:23 PM
    #3891
    grdgz97
    Georgetown, TX
    2015 TRD Sport DCSB
    We should somehow get a TW bbq challenge together! Unfortunately, we're not all near each other! :bananadead::bananadead:
  12. Aug 3, 2016 at 1:42 PM
    #3892
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I've been wanting to try this so bad. But have put it off until this fall for the temp thing. But if the cure has done its job it "should" be OK, right?
    Sorry to hear about your cheese, that's about my very favorite thing to do. Again I usually do it in the cooler months as well. I only have one package left from my last smoke (Jan.) small chunks of Gouda, cheddar and mozzarella. I'm tempted almost every day...
  13. Aug 3, 2016 at 2:21 PM
    #3893
    916carl
    Carl
    Regarding the cure - yes, it should be ok for longer periods since I used the Prague salt vs the quick cure, but there's a part of me that just couldn't trust it to go longer. First time nerves maybe. If this batch works out I may go longer next time. We'll see.
    We did 7 or 8 kinds of cheese in 2 batches: 1 hickory and 1 apple. About 2 hours on the hickory and 3 on the apple. Vacuum sealed them and let them age for something like 6-8 weeks. Both were ashy, but surprisingly the hickory less so. The only one I remotely liked was gouda hickory... Not sure what I did wrong. I'm gun shy about doing it again because of the poor results and the expense.
    Woundedyak likes this.
  14. Aug 3, 2016 at 2:30 PM
    #3894
    t4daddy
    North Alabama
    I think I remember those pictures of yours. It sure looks good. I went four hours with hickory dust, best I recall.
  15. Aug 3, 2016 at 3:03 PM
    #3895
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Electric smoker:
    Y'all use your chips dry or soaked?
  16. Aug 3, 2016 at 3:40 PM
    #3896
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    Trying this buckboard bacon thing.
    Polymerhead[OP] likes this.
  17. Aug 3, 2016 at 3:50 PM
    #3897
    t4daddy
    North Alabama
    I used to soak, then stopped. Now I only use dust.
    phx13[QUOTED] likes this.
  18. Aug 4, 2016 at 6:30 PM
    #3898
    Aloha Scout
    Aloha Scout Drink beer and smoke your meats
    Smoker Mod!!! Got the masterbuilt cold smoke kit in the mail. Double the smoke and very little heat transfer. An ice dish and some dryer duct will keep it much lower but I only have risen 5 degrees from when I turned it on an hour ago. Went from 79-84. Really loving it and would recommend it to anyone with a masterbuilt smoker
    Woundedyak and robssol like this.
  19. Aug 4, 2016 at 8:10 PM
    #3899
    wilcam47
    Will
    Bourbon state
    doe it use regular chips?
    Aloha Scout[QUOTED] likes this.
  20. Aug 4, 2016 at 8:11 PM
    #3900
    Aloha Scout
    Yuhhhp
